more numbers found:
49-0636-100 - Valve spring lifter (616 with 1586cc engine)
49-0259-440 - Main shaft holder (4 speed manual gearbox for VC engine, RX2 & 616 gearboxes also)
0223-440
0223-440A
49-0259-700 - Front shock absorber cap nut wrench (RX-2 & 616)
49-0221-030A - Ring gear brake (VC engine, 616 with 1586cc engine also)
0378-060
0259-705
49-0223-160 - Valve seal pusher (not sure about engine, for VC should be with "A" on the end)
49-0223-160B - Valve seal pusher (not sure about engine, for VC should be with "A" on the end)
49-0820-260 - Stationary gear lock pin remover (RX2)
49-0813-310 - Clutch disk centering tool (VC engine & RX2 also)
0259-310
49-0221-251A - Valve guide remover and installer (VC engine)
These there are 2 of:
0862-426
0249-010
49-0187-441A - Shift fork rod guide (4 speed manual gearbox for VC engine, 616 gearbox also)
49-0813-245 - Rotor bearing expander (RX2, RX3)
1976 Mazda 929 Hardtop Coupe
1977 Mazda 929 Hardtop Coupe
1977 Mazda 929 Wagon (donor car)
1981 Mazda 626 Coupe
1984 Mazda RX-7
http://www.mazda-929.ruhttp://www.oldmazda.ru
