It is currently Wed May 22, 2013 10:36 pm
Post a new topicPost a reply Page 20 of 28   [ 559 posts ]
Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23 ... 28  Next
PostPosted: Sat Jan 14, 2012 2:58 am
Awesome work gypsy, I love every post you make and can't wait to see it on the road again, it looks exactly same as mine, but a genuine rx3, would have been good to get both cars side by side for a few snaps! Keep up the good work!
PostPosted: Sat Jan 14, 2012 6:04 am
If you're around in 6 or so months (if Im not being overly optomistic) then then photos shouldn't be a problem. What are you doing with your old NA style exhaust system, size of pipes if selling ? I have a custom set of headers which will be going together but still need the rest of the exhaust. There was one on AR but its a little too big for my engine. A Savanna owner recently showed me an exhaust he recently put together on one of his cars and was blown away by the quality of work. I'd hate to think how many hours went into it, not something you'd get from any exhaust shop ! There is one other that I have detailed construction photos of, this guy even polished the entire system and looks amazing. I'm glad I'm not the only one around posessed by their projects. Im in two minds whether to build it myself or not.
Building the car has to come to an end at some point so the next one can begin :) I'll have another go at the doors shortly when I'm not so rushed to do other things. The short term goal is to have the interior all done and assembled in the next 6weeks. Not sure what to do about the seat belts, I can either buy aftermarket ones or have the original ones redone. The metal buckle tongues are a little pitted from memory so have to check if the platers can smooth out the rust pits with copper before chroming. The only thing stopping me going with after market (in the same style) is that if I ever decide to fit a Japanese dash to the car the buckles won't fit in the handbrake console buckle holders..... decisions... decisions...
Not sure if I've mentioned it here but Im looking at fitting an internal lift pump inside the fuel tank rather that have an external mounted unit such as a carter or holley pump. These pumps just make too much noise for the long trips I have in mine. After a bit of research Im looking at installing / modifying a Volvo 240 lift pump mechanism inside the tank. It seems like there isnt too much involved but still need to head out to a wrecking yard and take some first hand measurements before committing.
At the moment I'm trying hard not too start several things at once so that Im not overwhelmed with multiple tasks. Im also glad to report that switching to a wool cutting pad made compounding a breeze over the foam pad I was using. The wool is more aggressive but runs much cooler so doesnt mark the paint.
Hopefully I have a more substantial and exciting update next time.
Thanks worked it out, the rear window doesnt wind down like I expected. The window leading edge doesnt stay flush against the B Pillar like I thought. I think Im the dim wit that pulled this apart all those years ago so can't blame anyone.
The service manual was quite helpful. First mistake was to use one long length of weatherstrip instead of 2 seperate pieces like the service book illustration. By the looks of it the upper and lower B pillar weatherstrips are different shape, more on this further down.
So I cut the strip in 2.
The lower B pillar guide uses a deeper channel, so you really need this type of bailey channel. Dont worry too much about the overfit as long as its snug. The lower B pillar guide that sits within the quarter panel only ever touches one point of the quarter glass. Its sole purpose is to hold the leading edge of the glass firm as it winds up and down. If the quarter window lead edge was always snug from top to bottom against the guide then we'd have a problem. Its not designed to work like this so we are OK :) This is the type I will use through out the car. It has a nice moulded edge that protrudes approx 3mm outside of the channel like the old factory stuff I have.
This is the other type that is suitable for Mazda's (well Rx3 at least). Its perfect for the visable areas of the bailey channel but as you can see sits too shallow for the lower guides that sit within the quarter panels and doors (I assume as havent done them yet). The quarter glass will never touch the bailey channel as you wind the window down too support it which can cause you all sorts of problems with your window. I tried thinking it was the way to go until I worked out how its all suppose to work. This type sits completely flush in the visable areas ie upper door channels, B pillars etc. It just comes down to preference really. If you buy this stuff you will also need the other stuff for the lower areas for it to all work 100%.
The other mistake I made unknowningly, rear quide installed incorrectly.
This is how it should be. This fixed the problem of the glass not sitting perpendicular to the quarter panel edge.
Window winds up and down easily and firmly without moving about and falling out of the guides. Lots of grease from the winders getting all over the glass !
The glass moves away from the B pillar as its wound down. The leading edge of the glass is being supported up one point via the inner B pillar guide pictured previously.
The gap increases the lower it goes but the glass is still supported by the lower B pillar guide. You can now see why I spent so long trying and trying.
...and all the way down with no problems. I should clean the interior out before I go too much further otherwise I'll run into problems. Its where the rear half that really needs a good clean.
C pillar seal, just reused the old one which is perfect. I also noticed there is an upper C pillar seal which I think I have but need to find. Something I know I didnt remove. Noticed the screw holes above the window so I know something screws there.
Seal then crimped into place....
Glass cleaned and wound back up :) Stainless bits have been repaired just need a quick polish before final installation. I also have the plastic B pillar trim. Looks like the C pillar garnish that sit under the Super Deluxe badges will need a rechrome.
....just another shot. Will need the bit of masonite that seperates the boot from the rear of the car. Dont think I have it, but never know until I look ! Did I mention the rear needs a good clean and maybe a quick coat of primer .....
Last one for you Dennis, windscreen clips from a Magna. This is how they fit, got them from Rare Spares. Had a quick look on their website didnt spot them but they are there. MUCH cheaper and better than the plastic coated metal ones that Mazda sell. They will never rust and were about .60ea I think.
Front door locks and window next then I'll do the left side. (unless you think I got the rear quarter window all wrong... let me know if I did :oops: )
PostPosted: Tue Jan 17, 2012 4:36 pm
The rear end is so chubby shiny and chrome and new. Definately cant wait to see it with the windows in/up. great progress yet again!
I will take note of the bailey sizes and the channel depth when it comes to build day and also when purchasing rubbers now. :tu: found this great.
PostPosted: Wed Jan 18, 2012 2:26 am
Thanks, that side window is there by the way, just ultra clean. The bailey design is slightly different to original ones, however they fit really well without binding on the glass. You can see on the B pillar that the moulded edge protrudes approx 3mm like original and sits nicely. The other type sits perfect as well however does not protrude at all. I was going to scour the world for the original type but I saw little point after fitting a sample of this stuff.
This is the weatherstrip I sourced in bulk after being unable to find anything to my satisfaction through any of the local suppliers. I should have it in the next week or two. It's incredibly close to original if not identical. This is the inner weatherstrip that fits between the doortrim and glass.
This is the an old piece of the original Mazda stuff
This is the replacement strip that I've found. Pic 2, Another angle, pretty much identical to the original ones. It even has the little lip on the top edge that faces the glass.
Image Image
Anyone who wishes to buy some is looking at AUD$13.50 a meter + $10 postage Australia wide (suits sedan, coupe and wagon). I'll put a little "howto" together with the strip as well to make installation a breeze. I'm on the lookout for the upper seal that fits between the B and C pillars on top of the coupe quarter glass, think that's going to be tough one. Hopefully one of the local suppliers will have something close to save me a lot of trouble.
If I've broken any rules here I'll happily remove the post.....
PostPosted: Sun Jan 29, 2012 7:49 pm
i leave in april, i have a feeling thats way to early lol, i had such a pain in the ass with the rear windows putting them back in, making sure they all lined up correctly! as for the na exhaust, its either 1.8 or 2.1/4 i cant remember, i have a few people interested in purchacing the lot but there either real slow at replying or timewasters.. i still really what to get rid of it all at once but if nothing happens in the next month or so ill let you know as ill be pushing it for time and need to get rid of it,
PostPosted: Sun Jan 29, 2012 11:42 pm
No problem, just thought it could save a lot of hassle if it was what I was going to build. We'll see what happens I suppose.
Had started putting another update together to cover removing lots of nail catching scratches from door glass, hood lining install, front door assembly and the start of the electrical work which would freak some out if they saw the buckets of wires sitting on the floor...
Only problem is that I've run out of web hosting space so need to sort something out, you'll all need to wait a bit longer now especially with my work schedule :lol:
PostPosted: Thu Feb 02, 2012 3:53 am
Coming along now Gypsy. I wish I was up to the stage that you are at.
Can't wait to see the finished product. :D
PostPosted: Sat Feb 04, 2012 11:32 pm
First big update for the year, I hope to show off a complete interior sometime soon. I have lots of goodies waiting to be permantly installed. Everything from very nice door trims, seats, dash board, consoles etc etc. The little things always slow you up though.
Hood lining laid out in sun to iron out all the wrinkles from being wrapped up fo so many years. Pic 2 giving it a good scrub before installation. Its an original hoodlining that I got for free with other parts a few years ago. It has a couple of nics but aside from that it perfect.
Image Image
Laying out the original underlay and then bonding it in place with some Sikaflex which is non corrosive. You can see where Ive gone around the turret seams with wax.
Image Image
A couple of nics that Im repairing. They will never be seen. Basically I glue a thin foam strip over the nic and its done. The hood lining only had 2 little marks like this. I intentionally chose to use an original item over a new one. The original ones are easy to fit and you'll never get the heat press marks from a local trimmer. If they will do it you'll be paying big dollars. The only decent heat pressed trims I've seen that look good are Phils Doortrims. I've seen other more expensive ones made which arent nearly as good in my opinon.
Image Image
Same goes for here and then its ready for installation.
Image Image
I Sikaflex the rest of the underlay into place. Mental note: do not raise your head against the ceiling of the roof with Sikafex about. I had a heap of glue in my hair for a good 2 weeks ! Pic 2, spead the lining out for the retaining rods.
Image Image
Hoodlining in place, will need another good wipedown once all done. I also brushed some KBS sealer around the seams where the replacement panel was installed. This is where I believe POR and KBS has it's place. If I didnt have any I would of mixed up some 2K epoxy instead. Pic 2, probably went a little too far plating the door rods.... only did them I think because I was in a rush to drop everything off to the platers and didnt have to seperate parts.
Image Image
New hardware makes things easier and using tap and die for cleaning up old threads. Pic 2, corner triangle section installed.
Image Image
Bailey channels installled as was lock mechanisim. Locks where degreased and lub'd before going in.
Image Image
Screws and bolts replated. Pic 2 feeding down the bailey channel into the guide rail.
Image Image
Takes a bit of time and things can be a little tight but nothing hard about it. Pic 2 temporary bolt screwed into front rail to hold everything in place.
Image Image
The easy bit... fitting the rest before trimming.
Image Image
Almost done, then trim to correct length.
Image Image
The right rear plastic retainer strip was dried and cracked on the hoodlining so I cut off the damaged plastic strip and carefully unstitched the area. I then tucked the hoodlining into the retaining groove. Next I got a replacement section off another genuine Rx3 believe it or not with a torn lining and trimmed the replacement section down. The replacement section will keep everything nice and taught around that area. I then slip the replacement strip back in to groove, because of where it is and the constant pressure on it there is no need to stitch or glue in place.
Image Image
Pic 1, not the best photo but you can sort of see the profile of the flexible plastic strip that hold the rear of the hood lining in place. Its stitched to the hoodlining at the very front and the rear ends. Pic 2, after installing the door glass and having the regulator cleaned and plated I discovered it was stuffed. A trip down to see Tricky at Mazbitz sorted me out with a good clean one. Pic 3, you can see why the original regulator was all stuffed, it's opened up around the winder pivot. Replated one on left, good replacement on right.
Image Image Image
While I was down there Rick found a replacement passenger door glass for us as well. No matter how hard you look they all will need a cut and polish to having them looking good again. Pic 2 my car came with 2 drivers side glass, after putting the door together the first was badly scratched so decided to use the second one which was tinted probably 20+ years ago. The tint saved one side but the outer side still had a few minor marks. Im experimenting with the spare scratched glass, I've ground out all the nail catching scratches using a orbital machine. They are definately all gone now. Next I've got some industral glass compound which I'll mix up and see if I can get it like new again. In the mean time "the other" drivers door glass is more than good enough to use !
Step one, remove tint and give the glass a good scrape with a sharp edge blade. Then clean it up using some thinner or if you want something stronger a bit of paint reducer with do the job. Just keep the reducer away from your paint !
Image Image
I use an aggressive wool pad and some cutting compound on a 8" buffer. The glass will get a little hot as you work it, don't get it too hot because you'll know what'll happen :shock:
Image Image
Hard too believe its the same tinted glass. Pic 2, its then a 2 minute job slipping the glass onto the new regulator.
Image Image
Glass winds up and down nicely. I'll leave the window wound up for a few weeks to let all the new rubber bed into place. Pic 2, I trimmed the inner weatherstip and slip into place. Its 99% identical in shape and fit to original which I managed too source. I'll put up an ad later for people who wish to buy some from me. No need to spend hundreds on Mazda stuff which is no longer available.
Image Image
Need to start on this before the rear seats can go in. Pic 2, the under dash wiring and brackets all taped to correct nuts and bolts prior to removal. The internal harness is as good as you'll ever get minus a couple of minor things which I'll fix like new with a soldering iron and heat shrink. Radio area for one. You can see I also had a perfect inner firewall backing board (once dust free !). By the way Jed you were wrong about the masonite backing board, Rick and Dennis both said there is definately one and so does the parts book... back to rx3 school for you :)
Image Image
Headlight brackets and buckets are off to my mates for blasting. There are a couple of buckets that I did over 3 years ago and still no visible rust on them.
The rest of the update is on a few nice finishing touches once the exterior is given the once over a final buff and wax. Pic 1, for the benefit of others here is a new 12a badge that was only just offered to me. Here is a side by side comparision between 10a and 12a beaver badges. 10a badge has a chrome piramid like finish in the triangle bit while the 12a is textured with red resin. If they ever get used I'll have them rechromed. Pic 2 some bits that Mazbitz had redone (minus my finger marks :oops: ) And yes he refinished all 16 wheel studs to a mirror shine. Thanks go to Rob as well for the new 5 speed badge.... I'll send you something back as a thankyou. My car will be one of the only 5speed 10a Rx3s in Australia, can't think off too many who would have gone down this path, the badge will be a nice finish. Pic 3, some better close ups of the door handle and a few of the rechromed wheel studs that will be used.
Image Image
Shouldnt be too long before the interior is finished off. Will lay down some new tar sheet in the rear seat area, start by having the belts rechomed them mailed off to the belt webbing place, buy some finishing strip to hold the hoodlining in place, make a boot/ cabin masonite backing board and install some wires. If there is a defining photo of exactly how I want the cabin to look it would be an old photo posted by "big O" I think. That is the exact look Im after and nothing less. It just looks so damn good and I'll redo 20 times to get the same affect if I have too ! Basically it looks factory new in the best colour, black with a Japanese/ late 808 coupe steering wheel, everything is spotless, new, shiny where it needs to be and best of all using all Rx3 parts.... there is a photo somewhere in my build from memory 8)
PostPosted: Wed Feb 08, 2012 3:59 am
Slowly chipping away, at this rate I may actually finish the car :)
Pic 1, I have a good cabin firewall cover and perfect dash harness with new like mounting hardware. Pic 2 I carried out some minor repairs to the rear harness that connects to the main loom. Checked all plugs etc, nothing major required.
Image Image
Harnesses still have the factory number tags.... Pic 2 getting ready to install some cables
Image Image
The paint has a habit of cracking over the cable tags which makes things look a little tatty. Problem is solved by covering the tags with heat shrink and shrinking it with a hair dryer, much nicer.
Image Image
Pic 1 stuck the foam to the wheel tub. I know the factory had something similar on the 10a's not sure if I got it 100% right but the main thing is to prevent the steel rim rubbing off the paint. There are a couple of small holes with rubber plugs. I can't remember if these holes are factory or holes from the old tow bar. I welded most if not all of those non factory holes up wjen repairing the boot. Turned out pretty good I think for a scruffy looking boot. Pic2, rear harness installed.
Image Image
Cutting up some masonite to make a backboard that fits between the rear seat and tank. Dremel came in handy for a neat straight cut.
Image Image
Back board temporarily installed, fits nice. Pic2 some goodies that arrived recently, Japanese side wings and console/ handbrake bracket.
Image Image
Last 2 pics, found another pocket and side console brackets, they all seem to have the back cut out of them. Easy to have repaired though. I'd like to experiment making dies for the side brackets. Each bracket is 2 pieces, the smaller piece which is difficult to see extends from the main bracket and supports the rear of the pocket. Pretty easy to make, the main long ones are more difficult. If I manage to make some good reproductions I'll put them up for sale for a small fee, not high on the priority list to be honest as I have a very nice Australian dashboard to put into the car.
Image Image
Next update I may have the rear seats and door trims in place :)
PostPosted: Sun Feb 26, 2012 12:44 am
Not a great deal has happened recently, progress has been very slow over the past 6 or so weeks. Like others here I've been doing some renovating to my place that is at least 100 years old. Undoing the last 50+ years of patch ups isn't much fun. While patient with old Mazda's I lack patience working on buildings. Dealing with the builder isn't so bad, dealing with the local council does my head in ! So, my 2 week recent holiday break consisted of pulling very daggy tiles off walls, a bit of plastering, electrical, sanding, prep'ing walls, and some painting. So, after rushing around for 2 weeks in Sydney's crappy weather I flew back to Melbourne to only be told a new kitchen is going in. Can't win, so at the moment I'm pulling off wall tiles, floor tiles, cabinets and doing it all again. Not much time for Mazda's at the moment. I couldn't think of any better way to spend my holidays, unfortunately there is a lot more too go :(
At the moment I feel like selling up and relocating to the NSW coastal border near QLD, I've pretty much had enough of city life. I keep saying one day !
The harness and brackets have been installed behind the dash. Rather than bag and label everything like others do, I like too keep components whole too make reassembly much easier. The brackets and harness where removed as a whole unit. I tape any nuts and bolts to the brackets themselves so there is no guess work. Assembling the main brackets and harness literally took 5 minutes ! Pic 2, some bits that have been cleaned up. I've gone for the original black hood lining over a white one. Everything came up like new after a good wash. Handbrake was stripped and repainted, I've got some spare hoodlining vinyl to make up the missing B pillar trims. The vinyl will be dyed black. You can also see some 323 roof underfelt which I will use on the back board that separates the rear seat from the boot area.
Image Image
Pic 1, my car is the ultra rare Rx3 GS4 Capella version, not many of these about :) Pic 2 thanks again to Mazbitz for one side of the engine bay wiring harness and the door handle chrome work.
Image Image
Pic 1 things starting to come together. I had thought of fitting an aircon Jap spec console however I think I'll leave it for another car. I'm not too keen on drilling holes for the pipe work now that the car is freshly painted. The only thing Im not happy about with the standard consoles is the silver finish of the Rotary Engine console badge. I'll be chroming the type face once I get organised with an original reflective finish. Pic 2 the dash plate had seen better days, rust worm all over it lifting some of the old paint.
Image Image
Pic 1, handbrake had a similar problem so was stripped and repainted. Pic 2, DA'd the dash top.
Image Image
Pic 1, dash pad was recovered by Dash Doctor in Melbourne for $250. I painted the metal section of the dash in a matt finish then reattached to the pad section. Looking good ! Again, all the nuts and bolts were either taped or screwed into the parts so nothing got misplaced. Pic 2, I had one Japanese gear boot and one Australian spec boot made using original patterns.
Image Image
Other work currently underway. The original buckles and tongues will be rechromed and then sent off to a Australian certified seat belt place for new webbing. The belts are preventing the installation of the rear seats and door trims. If these were done I'd have seats in the car, rear ones at least. Pic 2 I bought some new speakers. The one in the dash was all cracked, the rear ones which are 5 1/4 " fit into the standard rear parcel shelf holes. I have a few mod cons in mind for this car just too make a little nicer and because I like playing around. Front speaker is 4" by the way.
Image Image
Factory harness and fuse box in place. Pic 2, cleaning up a Jap spec fan control unit. The ends of the levers were corroded so DA'd them and repainted. I've noticed 2 types of Jap spec fan control units. The main difference is some have clip on knobs others have screws retaining the knobs.
Image Image
Pic 1, the fan control unit is now together. Pic 2, cleaning up the heater box. First I check the water valve and hose for any old leakage. This one looks very good.
Image Image
You can see the entire unit looks very good....
Image Image
Unit is opened up to be cleaned out, lots of leaves.
Image Image
To reassemble, loosely attach brackets with screws them close 2 halfs together. The tape you see is holding the heater box to firewall nuts.
Image Image
Pic 1, don't forget to adjust the air flap lever. Pic 2, I'm swapping over the control unit too the Japanese one. The Japanese ones have 2 little globes in them which I need to replace before installing in car. One by one I swap the cables over.
Image Image
All levers are swapped over, pic 2 heater/ fan unit all done.
Image Image
Pic 1, side air units were also kept whole with all nuts and bolts. These need new foam around the flaps before they go in. Pic 2 underside of dash, windscreen vents attached.
I have a few quirky things that I'd like to integrate into the car. The AM radio will remain operational via the front dash speaker however, the front speaker will also act as a Mobile Phone hands free speaker. There will be a mic somewhere on the A pillar.
Rather than go for a conventional hidden radio/ MP3 player etc, I want the Andriod mobile to hook into a solid state PC that will be hidden somewhere in the car to provide the interface between the phone and the entertainment system. The plan is too use the 3G network via the phone for internet radio rather than conventional radio. The phone can also act as a media player. This way there will be no extra dangling cables required to connect an external media source. The only extra component will be a blue tooth sensor blended into the cabin somewhere. Still nutting it all out but I think it shouldnt be hard or expensive to achieve. Once I work it all out I'll post it up here as it comes together, it will all be done by me.
viewtopic.php?f=10&t=17421
PostPosted: Tue Mar 13, 2012 2:18 am
Another day another update, the puzzle is starting to come together.
Finishing off the back board between the tank and rear seat. I use a spray adhesive to attach the under felt.
Image Image
I ended up buying new pinch weld to fit around the door jambs and to secure the roof lining edges. Pic 2 while I was at it I cleaned up the door jambs from grim using a 3" pad on a air polisher. Made it an easy task. I wanted to do this prior to fitting the pinch weld to avoid splatter cleanup from the polish compound.
Image Image
Pinch weld fitted around quarter windows first. Roof lining in place, it's tough work removing all the creases, came out pretty good. Edges are all nice and taught, very sore finger tips though from all the pulling. Just don't pull on a 35yo + hood lining too much otherwise you'll be crying shortly afterwards when you tear it in half !
Image Image
Another roof lining shot.... Pic 2, rear seats temporary fitted. These were retrimmed in original style vinyl, they are a little dusty from sitting around. They were removed shortly after when I realised that the seat belts needed to be done. The wheel arch trims will be redone in new vinyl, I want a new looking interior.
Image Image
A close up the vinyl grain, not the best of photos (taken at night). They'll get a wipe down once the seat belts are ready to go in. The vinyl isn't smooth as earlier photos suggest. Pic 2, Just showing the differences between a 808 center console section and a Australian/ American console section. Rx3 one is on the right.
Image Image
This is a JDM center console section to fit a Savanna style dash, different yet again. Looks to be from an earlier style car judging from the finish. Pic 2, Dash frame and pad fitted to car.... looks nice, there is a piece of pinch weld that fits between the windscreen and dash frame that is yet to be fitted. I have a good original one which will be reused.
Image Image
Haven't mentioned the fresh engine in a while... it's still there waiting to be brought back to life. Its an old 10a Bridge Port using some old improved production parts/ housings that my mechanic had tucked away for many many years. He donated them to the cause provided they got used :) A little more painting to do to finish off small bits and pieces. Pic 2, I decided to fit an Australian spec dash, I have both dash types. To be honest I have no real preference as long as the dash looks new. I've seen these type of dashes go for much more than what I've paid for a much rarer Japanese dashes. People have gone made for Rx3 stuff these days, makes no sense to me.
Image Image
Last couple of photos for now.... Sorting out the harness and working on making the instrumentation functional. The harness is pretty good and doesn't really need much work. Sealing everything up so that I can fit the sound deadener sheets to the floor.
Image Image
After all these years its starting to look like a car again. I'll have some underlay ordered shortly, the carpet isn't far away either. I'll cut it to shape and have the edges sewn up with a heel mat for the driver. Rear seat belts are currently with the chromers, once they come back they will be sent away for new webbing then all seats can go in..... about time I started thinking about starting the engine.
PostPosted: Tue Mar 13, 2012 1:01 pm
Wow looking great, that was a great read as i have not caught up with your build from December. You must be getting excited now and forgotten about the pain that went into the body prep. Its a credit to you keep the updates coming.
PS where did you get the underfelt from?
Chris
PostPosted: Tue Mar 13, 2012 3:35 pm
Hey Chris, the underlay you see in the photos is from a 323 that sits above the roof lining. I grabbed it while I removed some 323 roof lining which is the same pattern as the Rx3 stuff. 626 and other early Mazda's are probably the same as well. It was used to complete the missing section on my B pillars between where the roof lining ends and where the rear quarter trims begin. You can see the spare roof lining section in the first photo posted in this update which was eventually dyed black. Nothing goes too waste on a budget build :)
You could go through a wrecking yard and easily remove enough underlay too do a car. I'm going for something a little better though and will be ordering this type of underlay with a butyl middle layer.
http://www.knoxautocarpets.com.au/sound_proofing.htm
For the floors I bought new tar sheets to lay down just like was fitted originally. I got that stuff from my Paint Supply shop. Some people go for the even more expensive option and fit Dynamat.
http://www.knoxautocarpets.com.au/dynamat.htm
Although I'm looking forward to the prospect of completing it, panel and paint is by a long shot the most enjoyable part of the build for me. Assembly isn't too bad watching it come together, but panel beating is far more satisfying and relaxing believe it or not ! Most peoples interpretation of assembly is fitting a couple of seats, a horrible aftermarket steering wheel, and a CD deck :lol:
I have at least another one or two or three Rx3 coupes in me. I'm really looking forward to buying the next one, I have a good idea of what I want which will fascinate a lot of people and challenge me far more than this project. No point doing the same thing twice !
PostPosted: Wed Mar 14, 2012 1:36 am
Yet another informative and helpful update for everyone..
The dash cowl section looks great, I'm definately a fan of satin and mat finish paint tastefully used on old cars.
The little dash speaker is one I have made several trips to auto shops to try and gauge an appropriate screw mount sizes and wattages etc... looking forward to the next update, all the bolt on parts are so neat! :tu:
PostPosted: Thu Mar 15, 2012 3:08 am
Thanks Mr Bean :)
I think there are only 3 sensible options when it comes too Rx3 dash clusters, they are export Rx3, JDM Rx3 and Mazda 808/818 (coupe). The craze with the fibreglass and alloy setups that we currently see in Australia look amateurish at best, not my sort of thing. I had the privilege of inspecting a genuine Group C Mazda Rx3 racer coupe a couple of months back, that car had a nice functional setup without all the BS. It even retained the genuine Mazda centre consoles.... it was the real deal, NOW that is the only exception I'd make to my 3 options above :)
Just got these after searching for a very long time. These are genuine Rx3 10a door trims with the carpet down the bottom. The vinyl and chrome is in excellent condition, I'll be buying new back boards and carefully fit them so they look 100% untampered with. I will only bond the pressed areas to the back board to ensure they turn out perfect. I'll then access whether its worth having any minor imperfection professionally touched up, I think they'll be right how they are :) Image Image
Unfelt is on its way... hopefully the next update will have a complete dash cluster.
PostPosted: Thu Mar 15, 2012 7:01 am
Im lost. I think my bebo/myspace/facebook & twitter acounts just overflowed and wiki leaked into my big pond.
http://www.youtube.com/watch?v=kAG39jKi0lI
My Videos
PostPosted: Thu Mar 15, 2012 9:28 pm
There's always the comedian :lol: Where have you been, it's been awfully quiet without you about ! No more super Mazda's coming out of the RestoreMaz factory for us too read up on :( Has it been all picnics and no work down Chipping Norton way or you gone back to playing with Barbi and Ken dolls :lol:
Dilly set me straight with his setup BTW :)
PostPosted: Fri Mar 16, 2012 1:39 am
Nothing at the moment.Too much work on.I sold my 323 and im on the prowl for something else.
My Videos
PostPosted: Mon Mar 19, 2012 11:28 pm
Ever thought of a Mazda 1000 coupe Dave ? I think they are one of the most under rated Mazda's of all time. I've sometimes thought of buying something like a Cosmo or R130 but I couldnt be bothered worrying about finding replacement parts. I think I've become more of a classic car lover more than a rotary car lover. A lot Mazda people have it all wrong, for whatever reason they feel the need to rotary power anything and everything with a Mazda badge.
Nothing major going on, bored of the car and sick of it taking so much space !
Dropped in to Dilly's place, he put aside a bit of his 90's memorabilia, I tried to get him to part with his bomber jacket and neon lights from from his Eminem rapper days, unfortunately he refused :( Pic 2 is a classic display of Dilly's dilligence, note the accent on top of the e. It's pronounced coup a, not coupe :)
Image Image
Seriously though, I needed an original board to have another made. As you can see from the underside the original board is there to make a good replica. I dropped it off yesterday to a trimmer in Sydney's inner West, should have it back in a couple of weeks. It'll be covered in a a rough grain vinyl which is very similar to the imprint on the factory masonite board. Pic 2, I also picked up some Cerium Oxide to polish out some scuffs from the passenger window. I'll give the rear screen a good buff as well unless I can find a new replacement one with a demister. I think the only piece of new glass available for these cars is the windscreen unfortunately.
Image Image
Last pic, I had new rear wheel arch covers made. I had a pair of originals but they had seen better days, no point using an original part if its in poor condition especially when the rest of the interior is like new.
PostPosted: Tue Mar 20, 2012 3:17 am
I had a 1000 coupe a few years ago...too hard to get parts for!
I wouldnt mind an 800 wagon i think. maybe transplant a 1300 motor into it with a small turbo ..something different .
My Videos
