It is currently Tue Jul 07, 2015 12:04 am
 Post subject: In Need of After market front suspension for my 1973 808
PostPosted: Sun Jan 11, 2015 11:30 am
So just like my subject line suggests I am in need of front suspension for my mazda 808, struts specifically.
finding replacement struts and springs has proven difficult to say the least and I was wondering if there is any rx3/808 fans out there that have replaced or upgraded their cars in the past.
any information or websites would be appreciated. and yes I'm well aware of pac.
thanks folks.! :D
 Post subject: Re: In Need of After market front suspension for my 1973 808
PostPosted: Sun Jan 11, 2015 6:19 pm
First generation Rx7 will bolt in. You will need camber plates to bring spindle angle up.
PostPosted: Mon Jan 12, 2015 12:39 am
I have some nos kyb replacement strut inserts for an rx3/808 I also have new rear shocks kyb
PostPosted: Tue Jan 13, 2015 3:43 am
Pretty sure Rx4 strut will fit. Different pcd on strut top tho. Plenty of springs/shocks/adj gear around, just gotta look. Ebay and google are a good start
Regards
PostPosted: Tue Jan 13, 2015 10:18 am
What are your plans with the suspension. Do you really want to upgrade the suspension or will a stock suspension do as well?
1977 mazda 818 1.3L 8V coupe
1992 mazda MX-6 2,5L 24V
www.dutchmazda818.nl
PostPosted: Tue Jan 13, 2015 7:58 pm
I dont think i'll be tubing it yet and the rear leafs will do just fine for the time being..
As for the front, a whole new strut would be just great along with a thicker sway bar.
I live very close to the rocky mountains and would like to take full advantage of those mountain passes on the weekends. Ill also be running 15's. I think they look sharper.. 8)
PostPosted: Wed Jan 14, 2015 12:56 am
If you still have the Original factory dampers (No inserts), you can also change the damperfluid for a thicker one.
Bikerstores can help you with that, for sure.
