It is currently Sat Feb 28, 2015 1:59 pm
 Post subject: How To Remove 1977 Steering Wheel?
PostPosted: Fri Dec 27, 2013 4:28 pm
I have a 1977 GLC FA4TS that I cant get the wheel off.Does the round horn center just pop or pry off?
 Post subject: Re: How To Remove 1977 Steering Wheel?
PostPosted: Fri Dec 27, 2013 4:40 pm
Should be push and twist, but some earlier ones did unscrew.
Mazda T600, Carol 600, Familia 800 and Familia 1000.
1960s Mazda piston power!
2003 Lexus LS430 sedan
2011 Mazda CX7 diesel wagon
1977 Honda Z50 J1 Mini Trail
Then there are the three fire engines.......
PostPosted: Fri Dec 27, 2013 6:25 pm
Well there was a lot of movement just in and out not to turn though.
Well I will try again till I break it. :td:
PostPosted: Fri Dec 27, 2013 7:44 pm
Are you talking about the old 2 spoke steering wheel with the black
centre cap? My old centre used to unclip by gentle persuasion, and it was
a pushfit back on.
PostPosted: Fri Dec 27, 2013 9:51 pm
Is it this kind of wheel?
If so, then you need to sort of peel the rubbery horn button off it's metal backing. You should be able to get something under the lip and it will come off pretty easily.
PostPosted: Sat Dec 28, 2013 1:11 pm
Yes thats the one thanks for the pic.,i did not take a pic. when i was at the jy.
I will give it a try.
PostPosted: Sat Dec 28, 2013 10:05 pm
The rubber horn cap pries off easily. Use a plastic tab or a flat head screwdriver with tape wrapped on the tip.
Under that is a 21mm nut.
Once you get the nut off, grab the wheel at 9 and 3 o'clock then alternatively pull each side back. The wheel should pop off without using a puller.
PostPosted: Sun Dec 29, 2013 6:17 pm
OK that sounds about what I was trying to do.Just gonna have to give it a little more muscle.Its been sitting for 25 years.
PostPosted: Mon Dec 30, 2013 3:59 pm
OK it popped off but I forgot my 21mil. :roll:
PostPosted: Sun Jan 12, 2014 11:52 am
Whit, where was this?
was it a 2door or 4 door GLC?
- Travis
PostPosted: Sun Jan 12, 2014 1:25 pm
2 door 1977 hatch.
steering Wheel on Ebay and front headlight bezels.
What parts you want?
