It is currently Thu May 23, 2013 2:10 am
 Post subject: Can a VB 1800 accept an MA crank for a small stroker?
PostPosted: Fri Feb 15, 2013 4:21 am
Short story, a friend is freshening a 1974 VB-powered Courier. Pistons are domed but sit 2mm in the hole. 8.3:1 seems too low. He's got a set of .75 over stock-type domed pistons and a long-tube header, Weber and adapter. Daily driver in SoCal.
I'll do a mild port job, match manifold, good seat work. He's looking for a cam choice. I may make a manifold to head spacer to add some runner length.
Adding 4mm stroke seems perfect way to get the pistons up to the deck?
Bearings look to be the same? F/MA? Wiki is vague and I haven't an MA crank to compare to the stocker.
Will zero-deck work without domes hitting head or valves? It'll be checked for clearance and minor notching is ok for us.
I'm assuming that 2mm of block cut is excessive and P'sO the tensioner?
 Post subject: Re: Can a VB 1800 accept an MA crank for a small stroker?
PostPosted: Fri Feb 15, 2013 4:29 am
8.3:1 with 4.778cc/mm of stroke and 61.529cc at TDC, 449.165 swept
Reducing TDC via pistons at +2mm (without stroke change) leaves 51.973 brings 9.64:1 CR
Adding 4mm stroke for 468.278 swept and 51.973 TDC gives 10.01 which seems OK for an aluminum-head hemi chamber?
PostPosted: Fri Feb 15, 2013 12:59 pm
I'm going to finish pulling my F/MA out of my 1980 626 this afternoon and hopefully final disassembly after that. Do you need any particular measurements from the from the crank while it's out?
PostPosted: Fri Feb 15, 2013 3:32 pm
Please! Pics and journal locations would be great!
PostPosted: Sat Feb 16, 2013 4:38 am
https://www.facebook.com/ajax/messaging/attachment.php?attach_id=a37d713bfe9ba001ac724ef4e3176d2e&mid=mid.1360983489866%3Aead3cea10d0ec28649&hash=AQBddJ7HYsIORmCM
PostPosted: Sat Feb 16, 2013 4:37 pm
Please? lol
PostPosted: Sun Feb 17, 2013 7:17 am
Got the engine out, but then ended up having to drive a friend 2 states away to pick up a car. Probably won't be able to work on her more until next friday. I'll make sure to post up lots of pics and measurements when I get to it though. Sorry about the delay man!
PostPosted: Sun Feb 17, 2013 4:57 pm
Haa. No worries. Thanks.
PostPosted: Mon Feb 18, 2013 5:21 pm
Try here fordcouriercollector.com
BLACK CARS ARE MEANER
