It is currently Mon Mar 02, 2015 5:46 am
Post a new topicPost a reply Page 2 of 11   [ 202 posts ]
Go to page Previous  1, 2, 3, 4, 5 ... 11  Next
Hub Caps or Dress rims?
Poll ended at Tue Jul 16, 2013 5:48 am
Hub Caps 27%  27%  [ 9 ]
Dress rims, original bolt and centre caps 73%  73%  [ 24 ]
Total votes : 33
 Post subject: Re: Rx3 Sedan build
PostPosted: Wed Jan 09, 2013 5:37 am
Old racecars not racing made baby Jesus cry :cry:
PostPosted: Fri Jan 11, 2013 3:28 pm
Back from blasting and very surprised. I have been scouring away with converter and will etch asap
PostPosted: Fri Jan 11, 2013 10:54 pm
That turned out all right, looks better than mine.
PostPosted: Tue Jan 15, 2013 2:51 am
Yes, defiantly a good shell. It has changed my thoughts on how far to go with it. Unfortunately it will take a bit longer I think.
I started making a rotisserie
It’s a 7/73 so I want it going by its 40th 8)
Pulling some parts out that I have had for a while and going through my nuts and bolts (36years of Mazda's) I want to make sure I use the right bolts and numbers on top off the bolts. :roll: might be a bit too much.
Nos
PostPosted: Tue Jan 15, 2013 9:59 pm
With the speed you work you'll be able to finish yours for it's birthday then finish mine for some Christmas time cruising before the end of the year :mrgreen:
PostPosted: Wed Jan 16, 2013 1:31 pm
Picked up the motor choice. It was going to be 13b mild port (all new plates and housings) but I want it as quiet and as smooth as possible. It will be standard setup, manifolds and Turbo.
Back in 89-90 I my Rx3 had a 12a with a HKS blow through Weber set up, went well for back then. 9 pounds of boost and I use to feed it import motors at $300 ago. It was a lot more driveable than a bridge port (except in the rain)
PostPosted: Wed Jan 16, 2013 3:42 pm
khs blow through like this?
viewtopic.php?f=17&t=22188
PostPosted: Wed Jan 16, 2013 5:52 pm
Yes, very similar. It ran rich but use to lean out and pop at high revs
PostPosted: Wed Jan 16, 2013 8:38 pm
thats not a good thing to hear. i hope i dont have the same issues :cry:
keep up the good work. envious of your chassis
PostPosted: Wed Jan 16, 2013 9:45 pm
Hey it was 1990. Stock N/A motors with 9 pounds (I might wind in the waist gate adjuster sometimes) It ran best at 6 pounds, N/A rotors. The motors would rattle with the higher boost but it was to late usually. I was doing the wrong thing :(
Thanks. Yes I am very happy with the body
PostPosted: Wed Jan 16, 2013 10:47 pm
Wicked luv the old school set up
http://www.youtube.com/user/turbo323re# ... w1bMr37C7w
PostPosted: Wed Apr 10, 2013 4:23 am
Ok been a while but been busy building a pergola out the back. So no time for panel work, off to get someone to do it for me. I would have rather do the work myself but no time and I would have got someone to paint it anyway. Car well on its way especially since it has only been there only 9 days.
I have been busy getting everything else ready to go back in when it gets back. Some trim parts will need some more attention but.
PostPosted: Mon Apr 22, 2013 3:49 am
Car is at the panel beaters a couple of pic’s
Digging out the parts
NOS hubbies
Cleaning up the lens and plastics
Polished up the mirrors
PostPosted: Mon Apr 22, 2013 3:54 am
Cleaning up the plastic with some Jiff
PostPosted: Tue Apr 23, 2013 4:34 am
Location: Still aboard the Deathstar with my Plasma cutter
Great progress thus far, though i did notice the plates welded to the inside of the chassis rails.
Is this done for engineers report or the sorts for 13BT ???
PostPosted: Thu Apr 25, 2013 3:45 pm
It was the biggest concern when I bought the car. I didn't know why someone would do it, problem I thought someone was hiding something bogey. I have some NOS rails so I didn't worry too much. The plate was only 0.8mm so it wouldn't have been there for strength. It is a mystery still I have cut them off.
Took my heat shield to my father in laws, he has a pneumatic planishing hammer. Made them like new forgot to take a before pic.
Polished the mirrors
Replaced all the joints (still need to do the inner control arms)
PostPosted: Tue Apr 30, 2013 4:12 am
Ok. I’m struggling with the radio. I have the original AM but they sound crap as we know. I have been looking for something. I tried my I pod with lead plugged straight into an old 2 channel AMP using RCA lead sounds a little less crap but.
I just want to some nice driving music, nothing flash. Just some Metallica or Tool(nice soft back ground music).
Looking at this but know nothing of them http://www.kicker.com/pxi502 or just go something like this http://www.classiccarstereo.co.uk/class ... audio.html
Anyone got anything. I really don’t know anything about stereos and only want something basic?
PostPosted: Tue Apr 30, 2013 7:48 pm
I'm surprised you don't have a ex Barry Jones 13B PP tucked away for a bit of music.
Does this meet your needs ? One of the Datsun guys is using one. Retain the original radio but use an external input for your mp3. I'm guessing the unit will drive a separate decent set of speakers that you can mount to the parcel shelf.
http://rediscoveradio.com/
PostPosted: Wed May 01, 2013 11:04 am
I would stay away from FM modulators if at all possible. But then i'm an audiophile snob.
That said, this device will go directly from a phone to the amplifier, bypassing the head unit completely:
http://www.ipodcarpros.com/Direct_To_Am ... _info.html
The thing with using ONLY a headphone-to-rca cable is you cant boost the line-level signal past max volume of the iPhone. This device boosts the signal in the volume control box.
This will bypass the original stereo, so if you want to listen to good 'ol AM talk radio you're SOL....
1984 RX-7 5-letter
PostPosted: Sun May 26, 2013 3:45 am
Thanks for the info. I think I will go for the classic setup.
Had a look at my car yesterday should get it back this week
Also playing with gearboxes. Using a BT50 rear housing on a series 4 gearbox. Everything was cool but speedo drive doesn’t line up. Now I will have to pull it apart and change the main shafts over.
