It is currently Sun Mar 29, 2015 6:11 pm
Post a new topicPost a reply Page 9 of 11   [ 202 posts ]
Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
Hub Caps or Dress rims?
Poll ended at Tue Jul 16, 2013 5:48 am
Hub Caps 27%  27%  [ 9 ]
Dress rims, original bolt and centre caps 73%  73%  [ 24 ]
Total votes : 33
 Post subject: Re: Rx3 Sedan build
PostPosted: Sun Jun 08, 2014 5:00 am
215/50/13 and 235/45/13 are 21.3 inch dia or 541mm
205/60/13 is 22.7 or 576
205/50/15 is 23.1 or 586
I am running 185/70/13 23.2 or 589
So that's a lot of stupid information
PostPosted: Sun Jun 08, 2014 6:00 am
Things are getting a little tougher for people using older small diameter rims. I had to import the tyres I'm using now to clear the front panels which they do by literally mm's. The idea of changing them was so I could use something more easily available.
I've seen some pretty cool older smaller rims recently but those Simmons would have to be on top of my list, followed by enki's that Selectmaz used on their old Rx3 red race car that was featured in Fast Fours issue 1, followed by some old Work Equips. I've found some rare stuff in my time but those Simmons would have to be ultra rare. Any how nice choice, also noticed the small diameter v4's in the background, haven't seen those in years..... :tu:
I'll stick with what I have until everything else is sorted. The meet is the first Sunday every month from 730 to 1030 I believe. I'll let you know a week out.
Dazz I used to ride an old road race bike up that road.... Seen a few stacks on that road over the years. Getting out of my bikes I think was the healthist thing I've ever done ! You don't see many cars on that road, haven't been there for a good 15 to 20 years.
PostPosted: Sun Jun 08, 2014 3:11 pm
For the authentic Group C RX-3 Sedan look, you need the 13" V4 style on the front with the low profile tyres, and the 8 spokes on the rear, lucky bugger you have both :twisted:
PostPosted: Sun Jun 08, 2014 3:26 pm
Speaking of tyre diameters, you might find this interesting, written by Ross Burbidge, who races the ex Don Holland RX-3 at Bathurst with Terry Shiel.
"The second advantage we enjoyed over Barry and all the other Rx-3s were tyres! Don had several years earlier determined that gearing the Mazda tall for Conrod Straight would negate any disadvantage up the mountain. If you look at any pics of our car at Bathurst you will soon spot the difference. We ran rear Dunlops with a 550mm profile (at other tracks we used 500 or 525). These 550 were special order from Dunlop in Japan and only available in limited numbers. I'm unsure whether any other RX-3 drivers ever tried and failed to obtain them. Scary to think that, thanks to them, we were travelling almost 130mph before pulling up at Murray's Corner with only 9" vented dics with 4-pots on the front & Mazda 808-sized drum brakes on the rear!"
PostPosted: Tue Jun 10, 2014 4:45 am
Yes tyre dia can make a big difference. I have 525 on the rear of my race car and they are no good for down the main straight at EC with a 4.4.
Next is what width. to get some new inners or outers it costs the same. So do you squeeze the biggest rim you can under the car knowing the tyres might be a problem or stick with 7's knowing 205/60s will always be there
PostPosted: Tue Jun 10, 2014 5:36 am
If you are sticking with 13s then be very careful. The last time I checked - early last year, there is only one manufacturer still making
"off-the-shelf, road " 205/60 x 13s and these are GT Radials. A lot of the old, low profile, wide tyre sizes we grew up with - because everything
had 13s and 14s back then, are no longer available. Finding a 13" tyre in a 50 or 45 profile that is not a semi slick and needs to be imported - good luck! :(
We are being forced to fit larger rims on our cars to get the tyre sizes we want! :evil:
PostPosted: Wed Jun 11, 2014 12:35 am
I still see the Dunlop SP Sport advertised here and there in 215/50/13.
http://www.ebay.com.au/itm/2x-215-50-13 ... 1258874469
Avon make a street legal 13" tyre which looks tempting too.
http://www.gordonleven.com/motorsport/a ... tyre=cr500
CR500 Road Legal Tyres:
175/55 R13 20.75" 527mm 7.24"/184mm wide in section, 6.34"/161mm tread, 604 revs per km.
205/55 R13 21.8" 554mm 9.06"/230mm wide in section, 7.32"/186mm tread, 575 revs per km.
245/50 R13 22.4" 569mm 9.92"/252mm wide in section, 9.13"/232mm tread, 559 revs per km.
205/55/13 should fit well on the front, and they'd be a hell of a squeeze, but 245/50's would look tough as hell under the rear :evil:
PostPosted: Sun Jun 15, 2014 9:22 pm
Looks fantastic mate well done :D
REgards, Mo Melville
PostPosted: Fri Jun 20, 2014 4:46 am
Say no to Simmons B45's. Such a horrible wheel!
With tyres, if you need to import some, check the price of importing them from the UK - sometimes they'll be cheaper freight wise than from the USA, even if the initial purchase price is more. Also, ask around some Mini workshops. Some of the mini nutters run wide 13's. I think Sime did some pretty wide rubber a couple of years back too.
 OnlineProfile
PostPosted: Mon Jul 21, 2014 3:00 am
Been slow with the injection, car has been off the road for 3 weeks and I hate it.
Manifold, Throttle body and linkage done. Fuel lines, regulator and pumps done. Just need to wire up the coils, sensors and injectors.
PostPosted: Tue Jul 22, 2014 8:10 pm
Is that one of the new age style throttle bodies that also contains an ECU within the throttle body ? A few US companies seem to be going that way now ie Holley, MSD.... probably others as well
Smart looking setup either way.
PostPosted: Wed Jul 23, 2014 8:05 pm
I like that throttle body set up with the air cleaner mods, little beast has all the bells n whistles yet looking stock, well played. :tu:
PostPosted: Thu Jul 24, 2014 3:58 am
It's an Xtreame Rotaries throttle body on a cut down Racingbeat manifold. I looked at those Holley/Edelbrock set ups not sure on the self tuning ones with a Rotary.
I am spewing they bought out the Black nylon hose just after I got the hoses, that would have made it a bit more Factory. I have finished all the mechanical stuff, now to the wiring. oh still got to adapt that stock filter.
PostPosted: Sat Oct 18, 2014 4:11 am
Well finally got my new outers, took 3 months :roll:
13 x 7 all-round. need to decide on a centre colour
I have the injection set up running but need to dyno it, will do next week.
Trying something a little different maybe. just need to put 2 injectors in the manifold
PostPosted: Sat Oct 18, 2014 3:31 pm
Those 13" Simmons look awesome, I'd be inclined to do the centres either black or charcoal grey if an understated look is wanted, OR, I think for the best look in the traditional Simmons gold colour like the V4's were always done in, is there a better colour for Simmons centres?
PostPosted: Tue Oct 21, 2014 12:03 am
The Simmons are going to look spectacular! 8)
1971 1300 Wagon Deluxe
1973 1300 Wagon
PostPosted: Wed Oct 22, 2014 2:55 am
PostPosted: Wed Oct 22, 2014 12:09 pm
Stunning :tu:
PostPosted: Wed Oct 22, 2014 3:35 pm
Very nice, I'd look for a set for my sedan if it was a bit further along. Then again I wouldn't want to upset you by copying you ! I wonder if they'll clear the coupe brakes, need a spare wheel to go in the boot.
You need some Yokohama A352's on them, that's what I used to use on my old Mazda's. I think one of the moderators here got a new set for his Skyline, they must do a run of them from time to time.
PostPosted: Wed Oct 22, 2014 4:43 pm
Yokohama call them the Y352 now, and while they aren't on their au web site, they do appear on other Australian tyre retailer web sites. Be they available or not all the time I don't know but they do seem to be for sale on and off still.
They are listed in the 215/50/13 and 235/50/13 sizes here:
http://www.tyreprofessionals.com.au/pro ... oduct/306/
Users browsing this forum: ewokracing and 2 guests
