It is currently Sun May 19, 2013 8:37 am
Post a new topicPost a reply Page 1 of 2   [ 29 posts ]
 Post subject: Project - Mazda Factory Race Rx7 S1 (aka Daytona #7)
PostPosted: Wed Dec 19, 2012 10:18 pm
Hi All
Thought I'd finally share my project, on the factory built Rx7 race car replica, as raced in Daytona 1979 race. Using the MFR components found in the Rx7 Competition Preparation and Service manual. It been a long/hard/costly project so far, with many hours/days/years searching the web for parts.
Here are some shot of the cars being tested back in the day, on which my car will be painted with light and dark green stripes.
Those cars were powered by the MFR 12a PP engine and using all the MFR parts bin. The list of MFR parts is a long one, look here.
Mazda Factory Race parts
Story so far, The Late Loen Prgomet started with my shell and install the new roll cage, rear control arm mounting to suit the longer MFR arms, drivers seat mount with cutting the floor (I'm a tall bastard), fuel tank and exhaust system. Once completed it was off to start the paint and panel.
Pic's of the cage and floor mod:
Back to bare metal....
Under coat and flares fit up....
In Polyester
Under car and engine bay in colour Aurora White (WN)
This is where the project is at and just waiting until the weather heats up for the rest to be painted and suspension is installed. Mind you about 400 hours worked on the body work so far, back to bare metal and rust repairs.
painted the cabin area. Flat black as the factory cars.
 Post subject: Re: Project - Mazda Factory Race Rx7 S1 (aka Daytona #7)
PostPosted: Wed Dec 19, 2012 10:22 pm
Then starting to paint up all the suspension, diff and front end aswell, so you'll have to hold out until then, for some of MFR gear...... :wink:
Well it painted, body only at this stage. Now for the spoilers, arches and doors, then the Green stripping.
Filling and sanding the spoilers...
The front spoiler will be done.
Here's the pic's, but only a mock up,(keep them off the floor) as still need the new bolts/fixings.
Very Happy and the look.....So far
PostPosted: Wed Dec 19, 2012 10:25 pm
painting the front and rear suspension stuff. Gettng ready to take the car off the spit, so we can paint the strips and flow coat the clear.
MFR Diff Housing
MFR Front Control Arms
Genuine MFR X Member
put togther the MFR front struts.
Started putting together the front ends and rear ends over the past week. Had to wait on some stuff from Mazda. ie new bolts and rear spring rubber mount.
Carrying out the trial fitt of the 14" SSR mk3 rims. Fronts are 8.5 and rear 11, will require new inner and outer rims spun up for the rear ones. The factory cars had 9"s on the front, but the 8.5 will done. (Save a few dollars where you can I guess).
PostPosted: Wed Dec 19, 2012 10:28 pm
Here's a pic of the MFR Brake Duct and MFR Steering Box, has a ratio of 2.7 turns lock to lock. Standard is around 4 turns, make the steering heavy.
its off the spit and rolling...... :D
The fuel cap fit.
Started fitting up the series 2-3 type front spoiler, as I was unable to find a genuine type to suit series 1. Cut the bumper off the top of the spoiler (as it was a one piece, see pic) and some trimming of the sides. The front apron middle section of the genuine one had to be cut. A little more trial fitting required and slight mods.......but looks great with bumper on, only a little gap between the guard and spoiler.
Play around with front spoiler and think this the best position, bit more sharping and undercoat to come. Once I find some nutserts and button head bolts for the flares, fit them up, touch up and then flow coating the car. Then the strips painted on, job done. (body work that is)
PostPosted: Wed Dec 19, 2012 10:31 pm
nice. It'll be a beautiful car when it's finished.
PostPosted: Wed Dec 19, 2012 10:36 pm
The cars now has been rubbed down and masked up. Few spots require a bit of white, then its onto the stripes.
Well the stripes are masked up, after around 10 hours, over a couple of days. Should have them painted by the weeks end, then a rub down with 2000 and flow coat. Plus i've just noticed the window door frame is blackened, so more painting to follow.......
Both colours done, now. \:D/
PostPosted: Wed Dec 19, 2012 10:42 pm
The cars now flow coated.......
PostPosted: Wed Dec 19, 2012 10:45 pm
The start of putting together the car.
Rear lights with new gaskets/rubber and lens. Just waiting on some bit and pieces from Mazda Japan.
Trying to use as much new parts as possible. :wink:
New vents, connectors and screws.
Taillights in, but just still waiting on the new washers, that fit around the lens screws. Also a new weather seal for the hatch.
New brake booster and clutch master, aswell a new bonnet latch.
New door handles
New door seals, inner and outer weatherstrips. Best to install the inner one first.
Mounted the pedal box aswell and cables
This is a series 2 pedal box, as i can't find the genuine clutch bracket, for the larger MFR brake booster could fit. Just cut the clutch mount on the fire wall and move it over 20mm.
PostPosted: Thu Dec 20, 2012 12:42 am
Gee you got that done quick Lloyd! :wink:
Love it! :mrgreen:
Cheers,
Danny
L10A
L10B
KPDA
KRBB
KTBA
M13P
TVA
VA
PostPosted: Fri Dec 21, 2012 7:25 am
Automotive erotica in the making!
PostPosted: Fri Dec 21, 2012 8:58 am
What an amazing project. Looks fantastic so far.
PostPosted: Fri Dec 21, 2012 10:51 pm
Killa job m8 looks killa... Can't wait to see next lot of pics
http://www.youtube.com/user/turbo323re# ... w1bMr37C7w
PostPosted: Sun Dec 23, 2012 6:10 am
Very impressed, keep it up, & DEFINITELY keep the pictures coming!
PostPosted: Mon Dec 24, 2012 1:00 pm
Wow...top notch work so far. Such an amazing build! Keep those updates coming!
PostPosted: Tue Dec 25, 2012 2:49 pm
Love it! :mrgreen:
Cheers,
Danny
Quick work indeed....now it's just sitting in the garage. Money stalling the project now! Buying to many MFR parts :shock:
Thanks for the kind words guy's......
PostPosted: Wed Dec 26, 2012 3:08 pm
Mate, you are the undisputed MFR king!!
Can't wait to see this thing done - much want.
PostPosted: Wed Dec 26, 2012 5:54 pm
Did you paint yourself Lloyd ?
Only problem about it being an authentic identical style replica is that your car would be far better finished than what it should be ! I've seen similar rear suspension modifications done to circuit Rx2's and 3's to make them handle, I never knew the extent of suspension mods to cars like this until the last few years. Up until that point I thought they were more or less road going cars.
What's it's main opposition and how competitive do you expect the car to be. Some of the classic car categories have become extremely expensive with big name drivers joining the classes.
viewtopic.php?f=10&t=17421
PostPosted: Wed Dec 26, 2012 11:32 pm
awesome !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! what a quality build
PostPosted: Sun Dec 30, 2012 2:23 am
LEGEN - wait for it - DARY!!! Awesome build mate
PostPosted: Mon Dec 31, 2012 8:16 pm
I can only dream of having this much time to spend on a project. You sir, have my utmost respect and envy. Beautiful work, like I need to tell you that.
71 240Z
73 Rx2
74 Rx4 GTR
83 Rx7 prepping for street/auto cross
