It is currently Wed May 22, 2013 9:48 pm
Post a new topicPost a reply Page 1 of 1   [ 20 posts ]
 Post subject: Deuce Rustoration
PostPosted: Sun Nov 11, 2012 12:05 pm
Floor pan replacement fabrication.
 Post subject: Re: Deuce Rustoration
PostPosted: Tue Nov 13, 2012 8:20 pm
The carnage of the rust worm
PostPosted: Tue Nov 13, 2012 8:34 pm
Inner rocker replacement in progress
PostPosted: Wed Nov 14, 2012 6:59 pm
Beads rolled in
PostPosted: Sat Nov 17, 2012 6:50 pm
Pan in process of being welded in place
PostPosted: Mon Nov 19, 2012 6:11 pm
Fabbing a compound floor patch on the planishing hammer
PostPosted: Mon Nov 19, 2012 6:14 pm
First fit up
PostPosted: Mon Nov 19, 2012 6:22 pm
Inside view
PostPosted: Tue Nov 20, 2012 5:28 pm
Floor corner tacked in
PostPosted: Tue Nov 20, 2012 8:44 pm
Beads rolled in...
Hey very good start looks good ... curious what did you use to make the... Bead rolls
came out very nicely.
kidrotary
PostPosted: Tue Nov 20, 2012 9:06 pm
kidrotary, used the harbor freight bead roller. Cost $149.00
http://www.harborfreight.com/garage-sho ... 34104.html
PostPosted: Sat Nov 24, 2012 12:34 pm
I got some more welding on the floor repair done. Also got the good repair in "temporary" paint; off the shelf duplicolor body shop series white
PostPosted: Sun Dec 02, 2012 4:30 pm
Rocker panel front edge shaped and in process of welding
PostPosted: Sun Dec 09, 2012 6:31 pm
Rocker panel and door panel repair complete
PostPosted: Sun Dec 09, 2012 6:34 pm
Stripped the door down
PostPosted: Tue Dec 11, 2012 12:28 am
Just noticed your white faced gauges, whats the story with those?
PostPosted: Wed Dec 12, 2012 3:57 am
Great job so far!! Very inspiring stuff. Keep up the great work :D
PostPosted: Sat Dec 15, 2012 7:16 pm
Decided to clean up the inner quarter area before remounting the fuel pump from the bastard mount that was in it
There was lots of rust inner the paint
PostPosted: Sun Dec 16, 2012 6:23 pm
Worked on rehabbing the exhaust system. RB header thru 2 RB presilencers, merges into a dual other RB muffler. It was poorly mounted when I got the car back in 2006. I decided it was time to fix the scraping and rattling driving down the road. Here is the RB muffler mocked into it's new position. I plan on reworking the valance opening for better aesthetics.
New mounts will have to be fabricated.
The pipes from the presilencers were poorly laid out. I was able to do the first bend in the harbor freight Bender, but the second bend wouldn't fit in the Bender, so I will have to do a pie cut to rotate the flange back to a vertical . Here is a pic before the pie cuts.
Eventually mandrel bends will be used to make new pipes
PostPosted: Fri Dec 28, 2012 10:19 am
Worked on cleaning up the gas tank mounting area. Will steam clean to remove degreaser residue and prep for paint this weekend
Image[
