It is currently Sat May 25, 2013 8:37 pm
 Post subject: 626 brake upgrade help
PostPosted: Sat Dec 15, 2012 12:10 am
Hi, I need some advice regarding upgrading the brakes on my 81 CB2 626. The old solid discs are really uninspiring so I really want to fit vented discs to the front.
Is it possible to fit SA22C front vented discs on my stub axle's, and can I use the calipers from the same car.
Any thoughts or ideas are welcome.
 Post subject: Re: 626 brake upgrade help
PostPosted: Sun Dec 16, 2012 12:38 pm
Hey bloke,
RX7 stub axle is different diameter and offset to CB2. I went through all this with my 626.
There is nothing "off the shelf" to suit our cars.
The quick solution is to fit the whole RX7 strut - providing you allow for adjustable strut tops
to correct the camber, can live with the front end being a good 3" lower than standard and tyres
wanting to scrape the guards! :(
(I have fully rebuilt S2 RX7 struts sitting at home with new rotors, bearings, pads - doing nothing
because I fitted them up, HATED how the car looked, and took them back out! :evil: )
The better solution is save your bux and get a custom set made to suit your car:
http://www.ausrotary.com/viewtopic.php? ... lit=plo13b
PostPosted: Sun Jan 20, 2013 5:41 am
I would like to second this suggestion.
