It is currently Thu May 23, 2013 5:29 pm
 Post subject: want to learn something about the RX7 turboII engine
PostPosted: Mon Jan 30, 2012 1:56 am
Hi guys,
I got a 86 RX7 TurboII accident car (180HP). Engine is stock, has only 10.000km and a full service (oil, spark plugs,...) was made last year.
Know I want to pull the engine out and bulit a engine stand where I can start it.
--> did somebody here make something like this?
I don´t have to pass emission tests with this car. So I want to keep only parts which are necessary. Want a clean engine bay.
--> Which parts are removable (like Airpump, ratsnest) and how? Anyone of you did it?
Info:
The engine will get a selfmade "back-turbo" exhaust and a GREDDY eManage ultimate System with wideband-lambda control. Also I have a Apexi AVCR for adjustable boost over rev. And I want to use E85 (85%Ethanol-Fuel) in the future.
This souldn´t be a race engine or something else. Bit more Power is okay .. maybee 200hp?!
I would be glad if anyone of you can get some tips or information!
best regards from the country of Felix Wankel :wink:
1999 TOYOTA Altezza RS200, XE10
1969 DATSUN Roadster, SPL311
1972 NISSAN "Hakosuka" Skyline GT-X, GC10
1994 TOYOTA MR2 Turbo (GEN3) *RIP
 Post subject: Re: want to learn something about the RX7 turboII engine
PostPosted: Mon Jan 30, 2012 2:39 pm
Hello,
When you say engine stand do you mean something like this?
http://www.youtube.com/watch?v=1lpUyc-GHcs :shock:
PostPosted: Mon Jan 30, 2012 2:59 pm
yes sir!
Here is another one:
http://www.youtube.com/watch?v=Tho7pX6-qJA
I have some exams untill 10th february.. then I want to put the engine out of the car and start building the "engine stand"
Will take pictures and post them ;-)
PostPosted: Sat Apr 21, 2012 4:16 pm
Check out rx7club.com in the 2nd gen technical section. There should be several faqs and archived threads about the TII. If it was a non-turbo I could tell you almost everything you needed to know but I've never dealt with the TII's. Good luck.
1988 Mazda Rx7 SE Maroon -215k miles and still spinning
1985 Mazda Rx7 GS Tender Blue Metallic (Resurrected) Now coming in dead last at an autox near you.
1984 Mazda Rx7 GSL-SE Tan(traded for '88)
1981 Mazda Rx7 donor car Red (only had for 2 weeks) RIP
PostPosted: Sat Apr 21, 2012 9:13 pm
banzai racing sells a block off plate kit for the 13b-t engine. also check resources on rx7club as previously mentioned.
viewtopic.php?f=17&t=22188
PostPosted: Sat Apr 21, 2012 9:44 pm
rotary car club also has a good forum
PostPosted: Mon Apr 23, 2012 10:49 am
Thanks for the infos!
I wanted to register at rx7club but didn´t get an activation email resent. Sent a contact form.
Anyone of you know what electrical devices are necessary to fire up the engine on a engine stand?
In the car I can´t start the engine with disconnected tachometer for example.
