It is currently Fri May 24, 2013 5:25 am
 Post subject: rx7 flooded now won't start after deflooding
PostPosted: Thu Apr 05, 2012 3:37 pm
Rx7 flooded then I tried to deflood it now it won't start.no gas no spark? Idk
 Post subject: Re: rx7 flooded now won't start after deflooding
PostPosted: Thu Apr 05, 2012 4:08 pm
check for gas and spark..
viewtopic.php?f=17&t=22188
PostPosted: Thu Apr 05, 2012 5:18 pm
How? Can you test the spark plugs like regular ones?
PostPosted: Fri Apr 06, 2012 12:44 pm
yes
PostPosted: Fri Apr 06, 2012 1:37 pm
Have you cleaned and dried plugs.Won't start if wet
PostPosted: Fri Apr 06, 2012 9:29 pm
Ok now i'm getting both but the only way it will do anything is if you block off the air intake then it starts goes to 1000 and then dies
PostPosted: Sat Apr 07, 2012 1:51 pm
Is the carb missing the choke butterfly(s)?
http://www.youtube.com/user/ColtSSR
'69 Honda C50
'79 Honda C50
'73 Honda ST90
Custom Honda Chaly
'85 RX7
'79 B1600
PostPosted: Sat Apr 07, 2012 7:13 pm
No its a 13b
PostPosted: Mon Apr 09, 2012 9:36 am
plug your maf back in
PostPosted: Mon Apr 09, 2012 8:19 pm
Josh go get the stock air box off that one in the yard.
