It is currently Sat May 18, 2013 2:12 am
Forum lockedPost a reply Page 2 of 2   [ 38 posts ]
Go to page Previous  1, 2
 Post subject: Re: my new project 1975' rx4
PostPosted: Wed Dec 07, 2011 1:21 pm
i have a question;
is possible to put the rear brake disk from rx7fb on rx4?
thanks
paint by Mother Nature!
join!
http://www.facebook.com/pages/Kamikaze- ... 0425072482
PostPosted: Wed Dec 07, 2011 9:09 pm
Swapping for the RX-5/Cosmo brakes is easier.
A mate of mine wrote this out a while back.
At the rear, there are a few ways you could go. The RX-5 bits DO bolt straight into the RX-4 housing, but there's a difference in the bearing retainers which means that an RX-5 axle in a RX-4 diff can move in and out by about 10mm... obviously, this is not good...
Solutions:
1. Whole diff swap. Cut mounts off both diffs, then weld RX-4 brackets onto RX-5 diff.
2. Machine up a spacer to fit into the end of the RX-4 axle tube.
3. Get the bearings pressed off the RX-5 axle, remove the retainer plate and replace with RX-4 item. Press new bearings on.
The remaining options get too confusing to explain here (read the linked diff thread), but suffice to say that in Tweety's RX-4, we'll be putting a whole 121 diff in. But if we were staying with the 3.9s, I'd definitely be in favour of option #3.
Which-ever way you go, you need an extra bracket on the body, for the handbrake cable. Ideally, you'd cut one off a RX-5 or 121 bodyshell and weld it on, but it's a simple bracket that would be easy to make and can be bolted on without drama (it bolts on under the rear seat, so no-one will be able to see the welds/bolts from the top).
It may be possible to re-jig the RX-4 handbrake cables to work on the RX-5 brakes, but I suspect that it'd cost you more at the cable-maker than fitting the bracket... but it would have the advantage of looking totally stock.
PostPosted: Thu Dec 08, 2011 4:56 am
Solutions:
thanks you, but is very rare a rx5 here :?
join!
PostPosted: Mon Dec 12, 2011 1:09 pm
just a clean up to see the bad old paint job ,
and a lettle test drive on the road: i have a brake locked,my rear tyres is deforme
but the engine is very good condition!run perfect (is a new :tu: )
join!
PostPosted: Tue Dec 13, 2011 1:23 pm
clean up!
before
after
join!
PostPosted: Mon Dec 26, 2011 2:36 pm
hello, i have a question :
exist the fenders flares for rx4?
join!
PostPosted: Mon Dec 26, 2011 7:59 pm
Already starting to look much, much better! :tu: :D
PostPosted: Mon Dec 26, 2011 9:26 pm
The FB Rx7 rear ends are nearly the same width as the Rx4 ones, because the FB rear end is a 4 link and the Rx4 is a leaf spring the rears don't swap in well. It can be done, what you will have to do is take both rear ends to a fab shop and have mounts swapped to the FB rear end
if you aren't going to use them I would be interested in the Cibie Fog lamps they would work well on one of my race car restos
Also I love the prototipio steering wheel although they are rare to see
PostPosted: Tue Dec 27, 2011 4:07 pm
thanks you
give me a offert for the Cibie ;)
join!
PostPosted: Mon Jan 09, 2012 2:10 pm
with the kp30 rotary of my brother
join!
PostPosted: Mon Jan 09, 2012 4:24 pm
Nice, I love the picture.
PostPosted: Mon Jan 09, 2012 5:46 pm
Why did you get rid of the spoiler? I know it was ugly, but your car could have been a 6 seater if you left it.
That car could literally fly if you turned it upside down.
Classic Mazda parts for sale
http://www.mts.net/~ryanbu/mazdacellar.html
PostPosted: Tue Jan 10, 2012 3:21 am
:lol:
join!
PostPosted: Mon Jan 30, 2012 10:01 am
Hi jfk,
J'ai lu que tu vends déjà ta RX-4 !!!
Je te l'aurais bien prise mais trop cher pour moi !
Bonne vente !
PostPosted: Tue Jan 31, 2012 12:32 am
Keep it in english please
So you're already selling this? How come?
PostPosted: Tue Jan 31, 2012 7:50 am
So did this car come from California I saw the old school license plate?
PostPosted: Tue Feb 28, 2012 1:24 pm
beuatiful specially without the spoiler. props to you bro :tu:
PostPosted: Tue Feb 28, 2012 2:18 pm
guys jfk sold this car
viewtopic.php?f=25&t=17369
so let the new owner start a new thread .. or not
