It is currently Thu May 23, 2013 6:38 am
 Post subject: Turbo with a Nikki carb?
PostPosted: Sun Oct 23, 2011 9:14 pm
Any guidance on this? It looks like there are not many people that work with nikki carbs these days. Should i just upgrade to the holley for turbocharging.
 Post subject: Re: Turbo with a Nikki carb?
PostPosted: Mon Oct 24, 2011 1:30 am
Blow thru or suck thru setup?
PostPosted: Mon Oct 24, 2011 2:44 am
What ever mods you need to do a holley you will need to do to the nikki.
A modded nikki probably wont be able supply the amount of fuel you need for turbo charging.
With all the mucking around just use a draw through Webber set up or get a cheap fuel only efi set up.
