It is currently Fri May 29, 2015 9:41 am
 Post subject: Spark plug question?
PostPosted: Fri Oct 07, 2011 6:02 pm
Just a question about spark plugs.
The engine I have is a 12a 6 port and its had mild porting I think , the spark plug I think it should take is a BUR9EQ is this right?
PS the eye brow is still on the plug holes.
Stu.. :idea:
 Post subject: Re: Spark plug question?
PostPosted: Fri Oct 07, 2011 9:18 pm
Here's a link to NGK specs for plugs:
http://www.ngk.com.au/sparkplug.php#
Generally the BUR series plugs came standard in the turbo engines -
13BT and 20BT, BUR7 or 8 EQ(leading) and BUR9EQ(trailing).
In my 13B secondary bridge, I'm running B9EGV. If it was an everyday driver then I
would probably run a slightly hotter plug - 7 or 8(leading), to stop them fouling.
There are lots of different plugs to suit your car, from 1 to 4 electrodes.
Take your pick. :D
PostPosted: Fri Oct 07, 2011 11:06 pm
Thanks for that. I need a long plug because of the eye brows on top of the holes.
