It is currently Sun May 19, 2013 6:28 pm
 Post subject: RX7 FC questions (mostly driveline related)
PostPosted: Fri Jun 03, 2011 12:18 pm
Okay, so I'm picking up a RX7 Series 4 GXL for parts. This means all the turbo goodies, without the turbo. I have a few questions:
1) I'm swapping over the four piston calipers and machining the rotors so I can continue to run my 14", four-lug phone dials per the writeup on Aaron Cake's website. Will the brakes still clear the wheels?
2) Will I have to change the brake master cylinder to run the four-piston front brakes?
3) Can I swap the rear center section to the LSD unit? What do I have to swap over?
4) How do I go about rebuilding the LSD?
5) Is the fog light wiring already in place? Do I just plug the switch and lights in, or will I have to pull the harness and swap that as well?
 Post subject: Re: RX7 FC questions (mostly driveline related)
PostPosted: Mon Jun 06, 2011 7:56 am
1. if youre getting a gxl, then why dont you just do the full 5 lug swap? not sure if 4 pot brakes will clear the tiny 14" phone dials
2. the brake masters are identical across the board for fc
3. as long as you are going from n/a to n/a, you can swap any center section in there that you want.. of course the s4 clutch type diff is preferred
4. i believe mazdatrix has a diff rebuild kit. or you can shim the clutch diff with beer cans.
5. dunno. just go look? its probably there though
viewtopic.php?f=17&t=22188
PostPosted: Mon Jun 06, 2011 12:46 pm
Thanks for the advice!
I want to keep the phone dials, I like to look of them. Mine are in immaculate condition, too. Plus, most oldschool rims are a 4-lug pattern anyway.
PostPosted: Mon Jun 06, 2011 1:17 pm
i dont really think that fc is oldschool yet.. but i do love them
here is mine
what i do with it
partnered with my lovely red fd
what i do with the other fd(that you see in the garage)
/hijak
♥ rotary
PostPosted: Tue Jun 07, 2011 8:26 am
Very nice! If you're posting rotary pictures, feel free to hijack my threads anytime.
Users browsing this forum: rolla93 and 1 guest
