It is currently Wed May 22, 2013 5:06 pm
 Post subject: my mazda 323 1977
PostPosted: Tue May 17, 2011 12:32 pm
hello, just joined this forum, i recently bought this wee mazda which im going to put back on the road, it has lay in a barn for over 25 years
only needs minor work to get road worthy, i is very clan inbellow, no signs of rot at all, have bought 2 new wings for it but now it just needs striped down and resprayed, the engine runs great, starts no bother and has only 36 thousand miles done, its auto at the minute but mite keep it that way cause would like keep it totally original as possible cause dnt think there is many of these left in ireland. this is going to be my first car ive restored, i just like the look of it and seem a great little car,
needs small wee patch welded where wing bolts as you can see kinda in the pic
 Post subject: Re: my mazda 323 1977
PostPosted: Mon May 23, 2011 1:30 pm
have front panels all striped from the car and started to treat the surface rust with rust eater, 2 small patches of rust to be replaced which are tiny and a easy fix
bought a exhaust system today new old stock
started to sand places of the car down to prep for paint
PostPosted: Tue May 24, 2011 12:20 am
Are you going to repaint it the same colour or a different one? They were avaliable in a range of cool colours back in the day if you want to keep it "original"
PostPosted: Tue May 24, 2011 1:51 am
had intended of repainting it the original colour, my mates dad has all the old original colour cards for cars and ive seen the colours they came in and do like the bright green or even the yellow like ur profile picture, my interior would match the yellow cause its light coloured yellow
PostPosted: Tue May 24, 2011 12:35 pm
carpets removed to check for rust, slight we hole about 10mm diameter under the throttle pedal thats all
PostPosted: Tue May 24, 2011 11:23 pm
Have you pulled off the panel under the windscreen wipers? It normally accumulates leaves and dirt and makes the firewall seam rust :( Also the sound proofing stuff in there can hide some rust holes too. I'd chip it all off to make sure. The bootlid and the bottom of the doors can be trouble spots too. At least your floor is in good condition. Yours is a 1.3L?
Mine is thunder yellow, which isnt very common. There is also yolk yellow and space yellow
Keeping in mind my profile pic is colour tweaked, it looks more like this
PostPosted: Wed May 25, 2011 2:39 am
yea have the panel under the windscreen screwed of and its is fine under there not even any surface rust,
was looking at the colour cards and the thunder yellow same as urs is real nice and would go with the interior and a nice set of wheels.
yea shes a 1.3, runs well, lay for over 25 years and started moreless straight away with the points cleaned and on the old petrol
PostPosted: Fri May 27, 2011 1:14 pm
new old stock exhaust arrived today, needed front scilencer but whole system was cheap so got it all
been looking throw alot of pictures and i had intended on keeping it pure standard but defo going to do a few mods think the bright yellow paint is a must and a nice set of chrome style wheels of some sort, have a brand new chromed back bumper so just need to either find a good front 1 or get it rechromed and it should look well when finished.
has any 1 ever tried wobble bolts, do they work ok
PostPosted: Sun May 29, 2011 1:12 am
very nice there mate, good to see another one being restored
Bruce
bog standard 1977 323 bugeye
1971 alfa 1750 gtv project
1981 Datsun 1200 Ute
PostPosted: Sat Jun 04, 2011 12:21 pm
havent done much else as need to sort out a new tax book for it as its been of the road that long there is no record of it so have to keep it complete incase they will need to verify the chassis, engine numbers etc
had a good look inbellow it to check everything and needs no work bar new brake lines and rubers
PostPosted: Tue Jun 14, 2011 1:05 pm
a small update
its going down to the local car tax office on friday to get the chassis, engine etc numbers verified for a new tax book, its been of the road that long there wernt even on the database
