It is currently Sun May 19, 2013 5:00 am
 Post subject: 1979 323 wagon, auckland new zealand
PostPosted: Thu May 26, 2011 10:01 am
hey guys, im a new member.
from auckland, always had 323s, this is one of about 6 ive owned, this was my second one, and only rotary converted one ive owned, had it for about 5 years, since i was 17 years old.
fell in loev with it the first day i saw it.
79' 323 wagon
sprayed in yellow, blacked out upohestery, everythings black and original, am radio, (amp under seat which runs one 4" speaker in teh standard hole in the dash with ipod cord so all is hidden)
GSII rx3 savannah coupe steering wheel
13x7 mogulars with 215 50 13 white writing yokohamas
13b bridgeport s4 non turbo block
mx5 gearbox
b2000 lsd diff
hardy spicer custon made driveshaft to suit
fully adjustable 1 off front struts
rear leaf spring, about to upgrade to ultra heavy duty rear shock out of VS commadore so nice and stiff
When i first got it it was low on some dirty mods, it was pretty fucking ruff, the guy i bought it off got it like thisImage
he ended up just treating it like shit so it was kinda ruff when i bought it. wish i had restored it to its former glory, but hey, i was young!
Im currently decideing weather to chop the modgies out to 13x11's on the read and 13x10's up front, because i have to run a 1" spacer to fit around the coil overs, the will sit flush, and run 175 50 tires so they will majorly stretched, or use 175 50 and do a little stretch on these wheels Image
they will space out nicely, but still undecieded.
opinions welcome!
 Post subject: Re: 1979 323 wagon, auckland new zealand
PostPosted: Thu May 26, 2011 11:45 am
А не подскажите какое растояние между болтами на ступице на этой машине?
PostPosted: Thu May 26, 2011 12:19 pm
If i translate correct here is the answer
the gold wheels are 4x114
my car is 4x110 on the rear, and because i have s3 front hubs they are 4x114 up front .
PostPosted: Thu May 26, 2011 1:05 pm
Thank you very much :tu:
PostPosted: Thu May 26, 2011 1:25 pm
I like drift.How do you think motor of my car Will cope with these load? :roll:
PostPosted: Thu May 26, 2011 11:09 pm
this doesnt make sense brother!
PostPosted: Fri May 27, 2011 10:11 am
Anonymous: 26 Jan, 2005 wrote:
1979 model. Standard besides 2" blocks in the rear compressed (I think) springs in the front. Has had a 5 speed box fitted too. Has white wall inserts and hubcaps off some Mazda but not sure what. Maybe someone knows...
Can't take much credit for it as I bought it like this a couple of months ago. Big plans though 8)
I did have this photo as the inspiration for mine for a while till I went a different direction.
Your wagon is going to look awesome on those rims too. How did you do the S3 front end conversion? Is it the same as the S2, but with different hubs? I was considering this to get a better selection of wheels
PostPosted: Fri May 27, 2011 1:46 pm
Hey dude, i got a factory set of s3 struts, then re vamped them, cut off spring seats, and got the weld on adjustable sleeves with cusco adjustable camber top hats, with the new shock i used a seris 2-3 shock, s1 shocks are 1" longer, but the 2 and the 3 series are that 1inch shorter, so its all set up to have tonnnnes of clearance.
im just having trouble finding a s3 caliper re-build kit, any ideas? Im SICK of dealing with mazda, every time ive ever spoken to them, they flog me off as the car is old, and they are simply lazy.
anyway, s3 brakes are the biggest of the rx7 brakes that came with the factory 13" wheels, i was lookin at some willwood calipers, but they were going to end up being way too expensive, and lets face it, brand new s3 stuff will be efficient enough.
Wheel fitment wise, with the front im going to run a 25mm spacer, and the rear will have a 25mm adaptor.
PostPosted: Fri May 27, 2011 3:08 pm
how much do modgies wheels cost ruffly
PostPosted: Fri May 27, 2011 3:14 pm
Modgies are cheap, advanti do them for around $780
brand new
http://www.trademe.co.nz/motors/car-par ... 421878.htm
PostPosted: Sun May 29, 2011 1:11 am
man those hd wheels are awesome, where might one find a set of those?
are for what sort of figure?
bog standard 1977 323 bugeye
1971 alfa 1750 gtv project
1981 Datsun 1200 Ute
PostPosted: Sun May 29, 2011 11:51 am
Hey dude, those wheels are super cheap, im getttin them for $800. Two hunhdy a wheel is a bargain. 0 offset too
the wholesaler is www.yhi.co.nz but i cant see them on there site, im going trhough a friend at firestone, and thats the wholesaler there.
there by hd racing, the model is called 'rsb'.
i saw they were branded konig on another site, but here they are branded in this auction as advanti.
i dont know how it works re naming stuff but yeah
http://www.trademe.co.nz/motors/car-par ... 439936.htm
and there 13x7
not 13x6
i dunno why this auction says 13x6 because they dont make them in 6s
PostPosted: Mon May 30, 2011 4:27 am
Nice I'll have to keep an eye out for some over here in QLD
they would look great on my ute.
Bruce
PostPosted: Mon May 30, 2011 5:01 am
Yep the new wheels look about 4 million times better than the modgies.
Nice little wagon.
My Videos
PostPosted: Mon May 30, 2011 3:35 pm
Tried them on last night, they looked great.
25 offset rules!
Only two sets in the country, apparently nobodys bought them, very un popular i suppose, lost my job this morning so have them waiting for when i come up with some dollars!
ill post some pix up of them when there all on with rubber.
PostPosted: Mon Sep 05, 2011 7:13 am
sweet wagz bro :D
PULSIFIER
PostPosted: Wed Sep 07, 2011 3:35 am
Hey mate,
Do you have Repco in NZ? If yes, then ask them about brake rebuild kits for your brakes.
I got complete caliper rebuild kits for my S2 RX7 brakes from them. :D
