It is currently Sun Jul 05, 2015 6:24 am
 Post subject: CB900F SuperSport Build
PostPosted: Sat May 25, 2013 8:48 am
Hey all, my main thread for this build is on dotheton.com, but I figured I can copy it over here and just keep both updated for now. I picked up the bike two and half weeks ago, and have been only working on the weekends here and there.
So I recently picked up a 1982 CB900f Supersport in decent condition, but covered with the most gaudy crap that you could imagine. Sadly the wasp style cone had the windscreen shattered, and was cracked above the headlight. I'll just let the pictures of the day I brought her home speak for themselves.
Clearly she was not the prettiest bike in the world, but that is easily remedied. Just pull all of the offending parts off of the bike.
Then try to scrape most of the stickers off of the tank....
Already she's looking much better
Clearly we won't need the mounting tabs for the side covers anymore
And the CV carbs are known to be a pain to deal with, so we'll just get rid of those..
as well as the stock battery box and electronics bracketry
First box of bike parts showed up yesterday!
Not a whole lot done yesterday. Put a set of drag bars on until I can find the right steel to make some clip ons. Ditched the original lights/blinkers/horn control in favor of a smaller unit for lights and horn only. I'm still not sure if I'm going to run a horn or not, but if I do, it can't be the stock one (well it should be stock two, but there's only one left and it's broken). Disassembled and stripped the layers of white, blue, more white, then black paint off of the clutch control lever. I then beat the clutch lever itself flat, it' had developed a bit of a bend from being dropped in the past it seems. I then mounted all of my controls, along with the new grips and bar end mirrors on the drag bars. The 1.9" tach was pretty straightforward to mount, just used some rubber grommets to act as vibration isolators, and she's sitting at the right height. The setup isn't quite exactly what I am looking to do, but it will work well enough for a mockup build and test rides. Speedometer, carbs, and muffler should be here this week. I still need to build and place the battery box, which I'm debating two positions for, either on top of the swingarm, or run an AGM battery and lay it on its side tucked underneath the swingarm. Then it'll be time to cut off her tail, weld on the hoop, install the tail light, tuck away electronics, make a seat, put on the new muffler, install the Keihin CR's, tune the new carbs, make my clip ons if/when I get around to it, and then take the whole bike apart again for paint, polish, cleanup etc.
Well, Saturday was time to get cracking.
First cuts were decent, but I came to find out that the frame had a second layer of piping inside of it as bracing.
Several measurements and a few cuts later, the hoop was ground down at the straight ends and tapped into the original frame. I had ordered frame slugs from DCC, but both ends were WAY too big to be used.
A little bit of welding and grinding later....
I figured since the hoop was on, I should go ahead and make a template for a seat pan
After a bit more cutting, it's looking just right!
Then I realized, I can't weld aluminum to steel, so I'd have to make something on the frame to bole the aluminum pan to. So I added a recessed crossbar near the hoop, (the other two at the transition from flat to curve we actually added later).
I also cut off and filled the bolt holes forward of the upper shock mount, near the rear corner of the triangle. Then I made an electronics plate to tuck most of the sparky bits up under the seat.
and a view of the elcetronics tray from above (this pic was taken before the two additional seat pan brackets were added)...
So progress was slow today, spent the end of the day pulling the header off, the stainless 4-1 was "clearanced" to go around the oil drain bolt, and over the years of neglect by the previous owner, the drain plug has been rounded off, and appears to have welded itself to the pan. I'm trying to decide if I want to yank the engine at this point just to extricate that bolt, or try tilting the bike forward, and draining the rest of the oil from the filter mount, suggestions?
Last big boxes showed up today, AGM battery, Muffler, new exhaust clamp, and my Keihin CR Specials!
Didn't get too much done yesterday. Put the new speedometer on, and after seeing it and the tach, I like them, but am going to have to make a better mounting solution. I don't like the angle the faces sit at on the brackets that came with them. I still need to add the Oil pressure, Neutral and High Beam lights as well, so I'm thinking it's just about time for more beer box templates.
Spent way too much time figuring out how to tuck the flasher, starter relay, and wiring harness up under the tank as well. It's currently a temporary mockup, held in place by zipties, But I'm fairly happy with how it's looking.
Got a rear fender cut down and mounted as well, still have to strip the chrome off and paint it though. It's big enough to protect the new Keihins, but still manages to tuck behind the triangle. I'll get some more pics today. Now I've got to look into cutting the "ears" off of the tank where the side covers used to pop on.
1982 CB900 Supersport build http://www.dotheton.com/forum/index.php?topic=49045.0
1980 mazda 626 build viewtopic.php?f=5&t=21748
 Post subject: Re: CB900F SuperSport Build
PostPosted: Thu May 30, 2013 6:33 pm
Spent an hour in the garage this evening. Finished up a battery box to put the new AGM battery under the swingarm, and then took an old chain and started making a helmet/jacket rack out of it.
PostPosted: Fri May 22, 2015 6:17 pm
good chop
PostPosted: Fri May 22, 2015 6:22 pm
Wow. Good work! :tu:
Wish I had enough patience to build another bike... :P
