It is currently Wed Jun 19, 2013 12:27 pm
 Post subject: Kingtoy's Suzuki GS750
PostPosted: Fri Aug 19, 2011 12:04 pm
Well I did buy a GS300 but that needed alot of wiring work that I didn't want to tackle. So I put it up for sale and went out and bought me a new bike. Here is my (new to me) Suzuki GS750. It is all original right now but I do intend to do the "bobber" treatment to it.
Jeff "Kingtoy" Brown
King of Toyotas
Custom 93 Toyota minitruck
 Post subject: Re: Kingtoy's Suzuki GS750
PostPosted: Mon Aug 22, 2011 6:48 pm
I like it. 8)
PostPosted: Mon Aug 22, 2011 7:16 pm
I like it. 8)
So do I. :mrgreen: I also realized that the front tire popped it's seal and won't take air now. Also, the ignition keeps wanting to lock the tree.
King of Toyotas
PostPosted: Wed Aug 24, 2011 8:05 pm
If you put it up on the center stand and have someone sit on the seat so the front tire is off the ground, it will pop back on the bead and air up. :tu:
But if it lost that much air in a week or two, sounds like there's a leak that needs fixing. :x
PostPosted: Thu Aug 25, 2011 7:30 am
Well I have bled the rear brake. I still need to get a battery and fix the front tire.
King of Toyotas
PostPosted: Thu Aug 25, 2011 5:03 pm
FWIW, mine was pretty flat, and had sat for 2+ years. I topped off the fluid, did an overnight low-amp charge and it came back to life. Worth a shot?
Hopefully yours has the smaller (cheaper) battery. Ebay is the best place to get the smaller ones. :wink:
PostPosted: Fri Aug 26, 2011 8:39 am
Well I took it to the shop and put it on Jonathan's charger. It seemed to take a charge, so if I have a minute I might try to pop it back in the bike and see if it will start.
If it does then all I need is the front brake master cyclinder. :D
King of Toyotas
PostPosted: Fri Aug 26, 2011 7:55 pm
If you want to learn from my mistake, drain the gas from the tank and put fresh gas in it before you try to crank it. :wink:
PostPosted: Tue Sep 06, 2011 9:21 pm
Well I hooked up the new battery today and gave it a go. It took a little bit, and I had to crack the throttle to start it, but it starts and runs. The idle seems off cause it won't idle on it's on when you lift off the throttle and I think the carbs are sticking some cause sometimes it hesitates before reving up.
So now I just fix the front tire, replace the front master cylinder and maybe try to clean the carbs a bit and we should be in business. :D :D :D
King of Toyotas
PostPosted: Wed Sep 14, 2011 6:10 pm
Woohoo! :tu: :mrgreen:
PostPosted: Thu Sep 15, 2011 7:38 am
Well a little update.
I have been starting it and running it almost everyday. Some days it runs better than others. It still won't idle on it's own though. It still smokes some, mainly out the right side. I also saw yesterday that it had leaked some oil around the bottom.
The front tire is cracked so needs to be replaced altogether. I still need to replace the front master cylinder and the choke cable.
I also need to finish the legal paperwork so I can get a title on it. (Ahem - John) :D
King of Toyotas
PostPosted: Tue Sep 27, 2011 6:38 am
Well I finally got a new front brake master cylinder installed, but can't quite seem to get it bled right.
Still need to get me a new front tire. I also need to finish all the legal paperwork. John, you and I need to get together, you need to show up this weekend bro.
King of Toyotas
PostPosted: Tue Sep 27, 2011 3:23 pm
New front brake master cylinder
Turn signals I will use
King of Toyotas
PostPosted: Wed Oct 26, 2011 7:15 am
Well I was finally able to take my bike on the road yesterday. I rode it from the shop to the apartment in Euless on 10. It is still way illegal but I enjoyed having my first ride on it.
King of Toyotas
PostPosted: Thu Nov 17, 2011 7:48 am
Well, my bike is all tagged and legal now (except for inspection). I even road it to work this morning.
It was a really cold BITCH!!! :o :o
King of Toyotas
PostPosted: Sun Jan 08, 2012 9:11 pm
Here it is currently.
King of Toyotas
PostPosted: Tue Jan 17, 2012 12:32 pm
Just when I think I got it all sorted out it screws me. I was having a charging problem on the bike. So after some research and asking some experts I figure it is the regulator/rectifier. I buy one and put it on.
Think that solved it, wrong. Me and my GF went for a ride the other day on our bikes and went to a local biker restaurant. Came out from having a drinks and boom battery was dead again. :evil: :evil: :evil:
WTF - so what the hell is wrong.
King of Toyotas
PostPosted: Tue Jan 17, 2012 7:38 pm
Did you ever put a fresh battery on it?
PostPosted: Tue Jan 17, 2012 9:18 pm
Of course, it got a new battery back in September.
King of Toyotas
