It is currently Mon Jul 06, 2015 7:45 pm
 Post subject: Honda n360 piston size?
PostPosted: Mon Feb 04, 2013 11:15 pm
Hey guys i just wanted to know what the honda n360 0.5mm oversize piston was for and if you could replace normal ones with this oversize one
Thanks
 Post subject: Re: Honda n360 piston size?
PostPosted: Fri Feb 08, 2013 11:42 am
The manual says over sized pistons came in 0.25mm increments. the cylinders/sleeves would have to be re-bored and new rings would be needed that fit that piston and the new cylinder diameter. Lots of parts search. Lots of real automotive machine shop work. Resulting in a minor cc improvement and thinner sleeves.
PostPosted: Fri Feb 08, 2013 4:27 pm
Thanks for the info was just looking at these http://www.ebay.com.au/itm/NOS-Honda-N3 ... 500wt_1203
PostPosted: Mon Feb 11, 2013 8:46 am
Thanks
Here you are:
PostPosted: Mon Feb 11, 2013 11:02 pm
Thanks alot deffently helped :) may i ask where u got that article extract from thanks
PostPosted: Wed Feb 13, 2013 10:20 am
You can get service manual here:
viewtopic.php?f=3&t=3679
PostPosted: Thu Feb 14, 2013 5:17 am
Check Sherwood Garage for oversize pistons and rings for the n360
