It is currently Sat May 25, 2013 9:06 pm
 Post subject: motorcycle carburetors on civic 1200 ???
PostPosted: Mon Nov 07, 2011 1:29 am
Hello,
I am thinking on adapting a set of motorcycle carburetors on a 1200cc Honda civic 1978.
in stead of using a set of RS carburetors, I was thinking of customizing 4 CBR600 carburetors...
somebody has experience with this?.??
or off course other types that are useable???
Kind regards
 Post subject: Re: motorcycle carburetors on civic 1200 ???
PostPosted: Tue Nov 08, 2011 1:15 am
Referring RS carbs I suppose you mean the twincarbs fitted to the RS Civic : these were Kei-hin I think and fairly similar to motorcycle carbs.
I had a Coupe7 which I just bolted on a set of 4 from a coupe9 and changed the camshaft to the 9 profile. The carbs all looked the same type and similar to the ones on the RS Civic and the S-600 / S-800, being CV type they are self balancing at higher throttle settings so if you are using similar carbs putting 4 on a Civic should be quite easy. Its worth changing the Cam to the RS profile and getting a 4:2:1 exhaust system like the RS had too. I did the RS conversion to my 1330cc 1980 Civic by bolting on the twincarbs and manifolds from a 1200 RS engine and it worked great. Wish I'd swapped back the carbs when I sold it because of the Civics sold here the hottest was the S version and that basically meant it came with a Sunroof (the engine was no different).
Ralph
set reactor to power then turbine to speed
