really is strange that after disassemble the carb and all the other checks is still doing bad...I am new with this engines so I can not give you a good advice to repair it but next step I recomend to you is to check the ignition coil and all cables of the ignition coil to spark plugs just in case, the other thing you can check if you didn´t do before is search for some air leaks or excess of fuel in the carb, sometimes are hidden and makes you get crazy. If you have someone with other carb like yours try it to be sure that is not the carb, then keep going with other things...last of all sorry for my english, hope is at least understandeable
Wish that you will find the problem soon
Greetings
