It is currently Sat May 23, 2015 5:12 am
Post a new topicPost a reply Page 3 of 3   [ 55 posts ]
Go to page Previous  1, 2, 3
 Post subject: Re: My AN600s
PostPosted: Tue Jan 15, 2013 6:32 pm
It starts fine and idles smooth. It really needs to be rejetted (smaller; solder and drill tiny). It also has no choke!!! It is only temporary since I have no other carb except for a motorcycle carb that has no accelerator pump or choke. It actually works fine as well. I am taking a different direction. I am building a Megasquirt EMS.
PostPosted: Sun May 19, 2013 7:08 am
Latest addition to the N600:
This is the initial start/run with no tuning. Basic modifications: Megasquirt II ECU kit from Diyautotune, throttle body injection form a 1995 Geo Metro. Single waste spark coil form a GM coil pack and a 36-1 trigger wheel made in my sons machine shop. Very temporary fuel cell made from an 88 Civic fuel pump and a plastic blast media container.
http://www.youtube.com/watch?v=9s8YFw-bF1U
PostPosted: Sun Jun 09, 2013 7:32 am
Trigger wheel with out Hal sensor.
I also added a GM temperature to the lower case.
PostPosted: Wed Jul 24, 2013 5:17 pm
The head is done. All the threads are heli-coiled, new valves and guides and every thing is flat. Someone had used a hand file on this head. I also had the upper case and barrel machined and the slots for the slipper dowels welded and milled to size.
PostPosted: Sun Sep 29, 2013 11:43 am
A little more body work. Had to see what this looked like.
I completed the spot welding, lots of flapper wheel sanding to smooth welds and remove old paint. Just a touch of Bondo to find high spots and fill low spots.
PostPosted: Sun Sep 29, 2013 3:03 pm
Looking great man!
Lover of all JNC's
PostPosted: Wed Oct 16, 2013 7:57 am
Only checking in to say you're doing some very inventive stuff with this motor/project! Had a look at the youtube link.. you're beyond my capabilities, so it's cool to learn by following this build.. Please keep us updated- your willingness to mod/experiment with your N is refreshing :tu: BTW- nice to see those ugly marker lights being shaved off :)
-ccrunner
My Honda N600 build log (major mechanical mods):
http://locostusa.com/forums/viewtopic.php?f=36&t=14452
PostPosted: Sun Oct 20, 2013 7:23 am
Many thanks ccrunner. I am at a point where I can put the new engine together. I need to stop coming up with different ideas and get this new engine running. The person I work with builds bullet proof VW engines with Chevy rods and BMW mains. He wants me to put a custom crank in a N600 so it can be rebuilt easily and completely. The idea is not that far fetched.
I follow your build as well. http://www.locostusa.com/forums/viewtop ... =36&t=1394. I like your solutions to problems that I would find overwhelming.
PostPosted: Fri Oct 25, 2013 2:36 pm
Love the EFI setup you have going there. Looks like a nice upgrade for these motors.
PostPosted: Sun Nov 10, 2013 5:49 pm
When the shift linkage sags enough to catch on the fire wall opening it is maybe time for a new rear motor mount.
I think I will make a mount that is closer to the Z600 design.
PostPosted: Wed Nov 27, 2013 3:02 am
I fixed this problem by filling the gaps with windscreen glue (polyurethan).
PostPosted: Wed Dec 18, 2013 9:55 am
Here is the new rear motor mount. It's a modified VW motor mount and new variation on N600 mount. Required a hack saw and welding. The only modification to the car was drilling 2 holes in sub frame.
PostPosted: Sun Jan 12, 2014 2:57 pm
Remote oil filter conversion. Everything but the lines, clamps and filter.
Image[/URL]
PostPosted: Sat Jan 18, 2014 12:00 pm
Dash is a work in progress as I get more gauges. Oil temp is my next addition.
Image[/URL]
Modified EF Civic air intake fits under hood.
Image[/URL]
PostPosted: Wed Sep 17, 2014 9:17 am
I had no idea people did so many cool things with these cars. Impressive.
