It is currently Wed May 22, 2013 1:46 am
 Post subject: Urgent! Need help before buying new rims!
PostPosted: Fri Nov 13, 2009 10:42 am
Hello to everyone! I have a Toyota corolla AE86 and it's the first time i modified it at the JDM stlye. I need help with my situation. I don't know if i should buy the rims 15 x 7 or 15 x 8 because i like it better 15 x 8 because it makes the car look more aggressive. I only have the original suspension. The springs are cut just a little bit.
My question is: I would have some problem or any inconvenient in putting the rims 15x8. The following below is the specifications of the rims that i want is sportsmax, but don't know if it is the correct ones to fit my car:
Brand : XXR
Model : 002
Bolt pattern : 8H (4x100 / 114.3)
Size : 15 x 8
Offset : 0mm
Lip Size : 3"
Which rims, what specifications and size would you recommend me to buy for my car could look more aggressive.
Thanks!
 Post subject: Re: Urgent! Need help before buying new rims!
PostPosted: Fri Nov 13, 2009 10:44 am
Brand : XXR
Model : 002
Size : 15 x 8
Offset : 0mm
Lip Size : 3"
Thanks!
The picture is showed on this webpage: http://www.uapone.com/ebay/002%20BLACK%20FRONT.jpg
PostPosted: Sun Nov 15, 2009 3:51 pm
dude, corolla's can fit way more aggressive wheels than that. You should save for some longchamps or something! :D
But yes, the 15x8 will fit fine
PostPosted: Sun Nov 15, 2009 10:51 pm
My friend bought my old 15x8 -20 boyds and they fit on his 86 just fine with some neg camber up front. 15x8 +0 will fit with no problems.
PostPosted: Tue Nov 17, 2009 12:08 am
From my experience, that should fit easily, i have owned one and have many friends with them and they run 8.5's with 0 or less offset and no issues, most of them run a bit of camber but that should be fine for your car. XXR's are decent wheels and much better than stock in my opinion but i see legit wheels like longchamps and other ssr's and some panasports and such go for around the same price, some need a little work but well worth it for a wheel set that will hold value and look better.
 Post subject: THANKS A LOT!
PostPosted: Tue Nov 17, 2009 7:03 pm
Thanks for your opinion, I live in Puerto Rico and its dificult to find old school rims at a great value. And i found these rims in a good price and looks like a little old school. My car is coming soon out from the shop and i need to get some new rims for the finish look.
Thanks to everyone who replied to my post.
PostPosted: Wed Nov 18, 2009 10:49 am
no problem man, post up some pictures when you get a chance! :D
PostPosted: Wed Nov 18, 2009 8:05 pm
I'd say they fit okay...
