It is currently Sun May 19, 2013 10:00 am
 Post subject: 83 Datsun Maxima/910 wheel offset
PostPosted: Sat Sep 26, 2009 1:42 pm
My friend Ed introduced me to this site today.
I found some really nice cars on here!
Done some searching already and had no luck.
Wanting to know the offset on factory wheels for my 83 Maxima/910.
Found a number sequence on the front of the wheel that says possibly
+35? Looking at putting another set of wheels on that are 16x7 +15 fronts
and 16x8 zero offset rears. I'm wanting the wheels to stick out past the
factory sheetmetal and run fender flares.
Here is a pic of my car.
Any help would help.
Thanks,
Brian
PostPosted: Sat Sep 26, 2009 1:43 pm
Here's a pic of the car with the wheels I'm asking about.
Thanks,
Brian
PostPosted: Sat Sep 26, 2009 3:43 pm
Those wheels are definitely in the +25 to +35 range.
To get them out past the fenders, we need to know your target wheel width for a recommendation on offset. :tu:
PostPosted: Sat Sep 26, 2009 4:15 pm
Thanks for the response........the +35 if what I was thinking also.
Thank you,
Brian
PostPosted: Sat Sep 26, 2009 10:22 pm
You want the rear rim to stick out of the existing fender right?
For your application, a 16x8 +0 offset rim will probably be on the same line as your fender or just slightly less. It wouldn't stick out. You would have to have a rim with a - (negative) offset in order for it to stick out of your fender. What is the original Maxima rim size?
PostPosted: Sun Sep 27, 2009 5:30 am
Yes, that is correct and the factory wheel size is 14x5.5.
Brian
