It is currently Mon May 20, 2013 11:46 pm
 Post subject: Squeaky brakes..
PostPosted: Thu Jan 31, 2013 6:33 pm
Brakes on my 85 Toyota Cressida(MX73) squeak.
Brake pads are new and I cannot find the problem.
any suggestions??
Thank you.
 Post subject: Re: Squeaky brakes..
PostPosted: Fri Feb 01, 2013 4:33 am
Is there air in your lines? Are they 4 wheel discs? Sometimes you need to adjust the shoes.
--Tristin
1969 Datsun 510 4dr.
PostPosted: Fri Feb 01, 2013 8:40 pm
has 4 disc's.
Vinny of the Kay.
PostPosted: Fri Feb 01, 2013 10:43 pm
shims? anti-squeal?
PostPosted: Sat Feb 02, 2013 8:38 am
And did you apply some copper grease at the back of the brake pads?
PostPosted: Mon Feb 04, 2013 9:01 pm
metallic brake pads, glazed rotors - or warped rotors, the caliper slider bolts getting stuck ( not lubed ), shims,. there are more causes.....
PostPosted: Tue Feb 19, 2013 9:45 am
what brand are the pads? I manage a brake shop and if you bought the eco brands im not surprised. also the more metallic they are the more they squeek when cold.
PostPosted: Thu Feb 21, 2013 11:06 pm
Don't forget there is a break in period too. New pads will have a rough surface from the factory, and won't seat up perfectly against your rotor's existing grooves until worn a bit, true even if they've been turned on a lathe. Usually more of a grind noise but if you didn't turn your rotors, it can be a squeak. Also, did you grease the areas where the pad backing plate moves against the caliper bracket?
