It is currently Thu May 23, 2013 10:29 pm
 Post subject: lowering my mx73..
PostPosted: Fri Feb 01, 2013 8:37 pm
I want to lower my 85 Toyota Cressida MX73.
I'm not sure how many coils to cut.
Anyone have experience with this?
or any suggestions??
Thanks!
Vinny of the Kay.
 Post subject: Re: lowering my mx73..
PostPosted: Sat Feb 02, 2013 11:01 am
Cut one coil at a time until you get your desired ride height.
Do you know what type of wheels you will be using? size and offset? that plays a role on how low you can go.
1980 Cressida MX32
Old Series Garage
PostPosted: Sat Feb 02, 2013 5:38 pm
Also youre going to have a bit of a shittier ride with cut coils. The shorter coils will make the ride bouncier which is not what you want with a lowered vehicle. If anything, you want a stiffer a ride so that youre not smacking the undercarriage going over bumps or having the wheel wells rub the top of the tires.
Im not saying dont do it, but just be informed. Lowering springs with a firmer rate are always recommended. If you have MacPherson front struts you can also make your own coilovers for about $40 which will be far better than cut coils.
--Tristin
1969 Datsun 510 4dr.
PostPosted: Mon Feb 04, 2013 9:50 pm
Thanks. Yeah, I'm just cutting the coils for now.
At least until I can afford to do it right haha
Vinny of the Kay.
PostPosted: Fri Feb 08, 2013 9:45 pm
cutting a spring in half effectively doubles the spring rate, so it will be stiffer.
the bounciness is usually caused by crap shock absorbers. cut springs with shorter-stroke shockers can give a pretty comfortable but sporty ride
PostPosted: Mon Mar 11, 2013 2:14 pm
Yup, every single MX7x cressida I have owned, first thing I did was cut 2 coils all the way around. Camaro shocks in the rear(1982-2000 doesn't matter) and either sw20 MR2 rear strut inserts or I have used AE92 inserts as well. Nobody ever knew I was running cut springs. Don't know what it is about the cressida, but it rides just fine on cut springs!
Sits great and rides nice!
1985 MX72 soon to be...
1991 MX83 soon to be 7MGTE
