It is currently Mon May 20, 2013 5:49 pm
 Post subject: Where to buy parts for the Toyota Corona mk2 (1973) ??
PostPosted: Wed Sep 19, 2012 4:40 pm
As topic says:
Thinking of window gaskets
Complete kit of bushings.
Thanks.
Regards... :)
 Post subject: Re: Where to buy parts for the Toyota Corona mk2 (1973) ??
PostPosted: Wed Sep 19, 2012 9:15 pm
For the window weather strips talk to "theunstated" in this forum he can help you out with those.
For all the suspension components, I can help you out with those. I have a complete list of every part number for the 73 rona mk2. Only bad part is, I have no idea where I left it. But check out the company "rare parts" they make every suspension component for the mk2.
If you go to an o'reilly auto parts, they have a way of getting you all the part numbers you need and ordering them. I used to work there, that's how i got all my part number for my 73 mk2.
Hope this help!
1973 Hilux RN22 (Daily)
1972/1973 Corona Mark ii Wagon MX29 (((FOR SALE)))
1994 Honda Civic EG8 (sold)
PostPosted: Thu Sep 20, 2012 12:03 pm
Thank you. :)
Please feel free to tell me more if you should remember.... :)
Regards.. :)
PostPosted: Thu Sep 20, 2012 1:44 pm
Just found the sheet...
Sway bar bushings #16117
Idler arm #20281
Tie rod outer #26217
Tie rod inner #26227
Tie rod adjustment sleeve #26208
Ball joint upper #10194
Ball joint lower #10202
Control arm bushings:
Front upper #15156
Front lower #15218
Rear upper #15285
Rear lower #15286
These are all made by the company "rare parts," since moog is a more common company, you might be able to interchange these part numbers off google.
Good luck! Hope this helps.
PostPosted: Thu Sep 20, 2012 3:23 pm
Thanks again. It sure helps! :)
PostPosted: Fri Sep 21, 2012 5:58 am
What about new body parts?
Do you know the thickness of the "body metal"? 0.6mm?
PostPosted: Fri Sep 21, 2012 8:54 am
I have no idea on that. Body parts are so hard to come by for 73. Anything new would be pretty much non-existant. Everything would be pretty much used.
Is yours coupe, sedan, or wagon?
PostPosted: Fri Sep 21, 2012 9:12 am
http://i993.photobucket.com/albums/af60 ... 3522ab.jpg
http://i993.photobucket.com/albums/af60 ... 4f261c.png
My car... :)
PostPosted: Fri Sep 21, 2012 10:11 am
Very nice, everything looks in order with the body, how come you're looking for new parts?
PostPosted: Fri Sep 21, 2012 1:19 pm
The front panels is not aligned with the door... The pictures are lying... Big time... :S
Panels have sunken down and are interfering with the door... Specialy on drivers side... :(
The bushings list that you wrote down... Is it for the entire car?
PostPosted: Sat Sep 22, 2012 12:09 pm
I see, pictures can be deceiving!
For the most yeah the list is pretty complete. Suspension wise, minus shocks and control arms (and the bushings that come with the control arms.)
A lot of the products, if you get the measurments of say tie rods, control arm, ball joint etc. You can easily look up energy suspension parts as well and more than likely find the same size from their website. Just by going off the dimensions of measuring your old one. Plus energy suspension is all poly-urethane.
PostPosted: Sat Sep 22, 2012 12:58 pm
Ok. Thanks. Will check it out. :)
PostPosted: Sat Sep 22, 2012 3:57 pm
Great looking car! I have the same.
PostPosted: Sat Sep 22, 2012 5:02 pm
Thanks for that. Got any pictures of yours? Interior and so on...?
I found the car online 14 days ago and just HAD to buy it...
I payed 2000$ for it... Well worth the money I think...
Plans are total teardown and rusttreatment, new bushings and suspension (any tips on suspension?).
Engine plans: Stock Toyota Blacktop with T50 transmission...
