It is currently Tue May 21, 2013 7:52 am
 Post subject: Help: Installing Japanese Talking reverse horn
PostPosted: Mon Apr 23, 2012 6:12 am
I got these JDM talking reverse alarms...
I need help with the wires, It has seven wires from the harness excluding the ground wires (8 in all) and i dont have any idea where each wire goes.
I plan converting it from 24V to 12 V to use on my car. Normally these are installed on trucks. some say when you signal left and right it also talks.
Has anybody done this or installed on his/her car. It would be so cool to have it working and talking....." ting ting bakushimas...ting ting"
These are as big as my fist.
Your help would be most appreciated. Thank you. :D
 Post subject: Re: Help: Installing Japanese Talking reverse horn
PostPosted: Sun Apr 29, 2012 10:27 am
if they do what you say they do i want them too :)
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Sat May 19, 2012 6:05 am
they usually work off the reverse light switch on the gearbox, so they only work when reverse is selected. one will be an earth, one will be power from reverse switch, and maybe 2 more from the indicators for when they flash. i would just earth the ground wire, and put a 24v source onto each wire and see what happens
1981 nissan c31 laurel
1984 datsun 910 wagon
PostPosted: Sun Jun 24, 2012 2:25 pm
Hi Jetto, where did you source these?
PostPosted: Sun Jun 24, 2012 4:24 pm
These things are pretty cool :D
PostPosted: Thu Jul 05, 2012 11:11 am
* i bought it from an importer of used truck parts.
Fortunately i was able to source these from japan. these are brand new items and wiring is much more simpler, just three wires that go to power, ground, reverse.12 Volts. I sell these items here in our country. Retails at $69.00 U.S. dollars excluding shipping.
Has a female japanese voice saying Bakushimas with chime sound while backing up. "Ting ting Bakushimas Ting ting"
it sounds similar to this:
http://www.youtube.com/watch?v=Izoiz-W6 ... re=related
PostPosted: Wed Jul 11, 2012 11:38 pm
bukishimash ting dong! :P :P :tu:
