It is currently Mon Apr 27, 2015 6:41 am
 Post subject: can you help with wheel choices...?
PostPosted: Thu Mar 22, 2012 5:10 pm
I'm looking to buy 4 new tires and rims for my '84 Nissan 720 pickup.
not sure where to start?
I know I'm looking for a high quality 4 season all weather tire.
how limited am I when it comes to finding new rims for my truck?
any help appreciated.
thanks.
 Post subject: Re: can you help with wheel choices...?
PostPosted: Thu Mar 22, 2012 6:03 pm
It has the same bolt pattern and similar offset as 90% of the trucks on the road, so not hard at all. :tu: :mrgreen:
Start with GM wheels (Chevy Truck, Cadillac Escalade, Suburban, etc.), then try different options from newer Nissan trucks, or almost any 6-lug truck. 8)
The real question is what size are you after? Anywhere from 15" to 20" is readily available.
PostPosted: Thu Mar 22, 2012 6:04 pm
Also, moved to proper section. :tu:
PostPosted: Thu Mar 22, 2012 6:21 pm
Prime example, 2000 Frontier wheels, as seen elsewhere on this forum. 8)
PostPosted: Fri Mar 23, 2012 1:47 pm
I'm not limited by size?
I don't want to add spacers and such.
I was thinking only 14" - 16"
to prevent rubbing.
I am going to check out some junk yards now that i know I have a very compatible bolt pattern.
or I may just keep my current rims, which I do like but they need sand blasted or something.
thanks for the reply's!
