It is currently Tue May 21, 2013 8:13 am
 Post subject: 215 on 15x10
PostPosted: Sun Jan 15, 2012 12:53 pm
So I'm a noob at stretching a tire but I'm pretty sure this is possible. I have a set of 215/60/15 winter tire that I want to use till spring or they wear out. I also want to learn how to stretch tires so I can do it myself when I need to. So I headed out to the garage to try it out for the first time ever and...no luck. :( I got the tire on the wheel and grabbed some brake cleaner, sprayed it in just like you tube shows and lit it. The stuff flamed up but the tire didn't move at all. I sprayed more in a coated all around and same thing. Flames like crazy but no head popping. What is the trick? What am I doing wrong?? The video I watched showed the one bead seated and the tire set on cinder blocks. I have. O clue on how to seat the fist bead or the second one.
Some please help me. I'm kinda committed to this set up.
 Post subject: Re: 215 on 15x10
PostPosted: Mon Jan 16, 2012 9:26 am
No fire involved with this technique:
http://www.youtube.com/watch?v=lzxHYEdA8Qo
86 Toyota Corolla GTS
85 Toyota Corolla GTS
72 Honda Z600
PostPosted: Thu Feb 23, 2012 12:28 pm
you have to have air hooked up to the stem while doing the fire method....watch the videos closer...would be easier to go the bike route
