It is currently Thu May 23, 2013 5:37 am
 Post subject: Re-Drilling wheels from 4x114.3 to 4x110 Stud Pattern?
PostPosted: Sat Dec 10, 2011 1:57 am
I've been looking for some 14x7" Enkei Cross Fevers for my RX-4, which has a 4x110 stud pattern, and the few wheels I have found are always 4x114.3.
There appears to be plenty of meat to do this, I assume the fill the existing hole with some kind of bung and then re-drill the holes to the new stud pattern.
Has anyone had their wheels modified from one stud pattern to another, and does anyone know a good place to get this done in Sydney, Australia?
 Post subject: Re: Re-Drilling wheels from 4x114.3 to 4x110 Stud Pattern?
PostPosted: Sat Dec 10, 2011 5:22 pm
I'm going to have this done to my wat's.$40 a wheel down in vic. Neales do it as well in Sydney for 75 a rim. They redrill and use an offset plug with a new hole position.114 to 110 is fine, anything outside of that range will cause you trouble. If there is lots of metal like you said you should be fine.
viewtopic.php?f=10&t=17421
