It is currently Wed Jun 19, 2013 10:51 pm
 Post subject: A Little Twist on Baby Supra Rims
PostPosted: Fri Nov 18, 2011 12:27 pm
Just posting this to give some people an idea that small little details may change the look on your rims, not a drastic change, but simple and effective. Most of you are familiar with the Baby Supra rims, whether OEM or aftermarket, and they usually come as pictured:
Chrome with plain metal inserts.
So, I decided to give the rims a bit attitude or enhancement per se. Of course, this procedure isn't new and was done decades ago, but it's a nice touch.
Things I used:
- Brillo Pad
- Masking Tape
- Razor Blade
- Black Primer (Dupli-Color Aerosol)
- Black Enamel (Dupli-Color Aerosol)
- Patience
First, I filled a bucket with water and soap in order to lubricate the scuff pad/brillo pad during the scrubbing of the inserts. I advise you to wear gloves as my nails were filed down using the brillo pad. When done, I washed the rims with soap and water to rid any contaminents, and dried them with a soft cloth.
Now the masking process.
Here comes the patience part. I used the razor blade to cut off the excess tape on the accents. This is very time consuming, can't you tell? Ok, before I applied any primer, I made sure to remove every little piece of tape and used compressed air to blow off any particles. I then used a bit of thinner on a cloth to rid the inserts from contaminents. It was time to lay down the primer (2 coats - waiting 10 mins between). After 20-30 mins, I finally layed down the black enamel (2 coats of each 5-10 mins apart and the 3rd wet coat to give it that shine).
End result
1980 Toyota Corolla 2DR Sedan - 3TC Street Modded
1980 Datsun B310 Coupe - Low + Slow
2006 Scion xB - DD
 Post subject: Re: A Little Twist on Baby Supra Rims
PostPosted: Fri Nov 18, 2011 2:22 pm
Looks good, I'm about to do the same thing to a old set of Midland Metallic wheels I've been trying to sell, they just need a little something to make them pop. Good job!
(Oo\ DATSUN /oO)
PostPosted: Wed Nov 23, 2011 6:39 pm
were there any aftermarket baby supra rims?
PostPosted: Wed Nov 23, 2011 6:59 pm
looks good!
Me: Image JTIN Classics: Image
PostPosted: Wed Nov 23, 2011 7:23 pm
Thanks guys!
Yes, Eagle Alloy/American Eagle Wheels did make a replica. I remember buying a pair of skinnies around 04-05 at a local shop. I don't remember the model number, but I think they stopped making them a few years ago. I'll try looking for a model number.
2006 Scion xB - DD
PostPosted: Wed Nov 23, 2011 10:59 pm
Found some info online, not sure if they continue to make them though.
http://www.eaglewheels.com/050.htm
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=50
2006 Scion xB - DD
PostPosted: Fri Nov 25, 2011 2:13 pm
so maybe these are replicas
because i dont find any stamp that toyota used..
and they inner lip holds a cap, the cap is not screwed...
PostPosted: Fri Nov 25, 2011 2:40 pm
I believe those are legit. I can tell by the center of the rim with the ridges and the red painted center insert. My brother has a pair of those. Definitely OEM. Polish those suckers up.
2006 Scion xB - DD
