It is currently Thu May 23, 2013 8:31 am
 Post subject: Adding a passenger mirror
PostPosted: Mon Aug 08, 2011 9:29 am
So, I have an 80 Corolla that I want to add a mirror to the passenger door. My question is, what is the best way to do this? Aside from just craming 2 sheet metal screws through.
 Post subject: Re: Adding a passenger mirror
PostPosted: Mon Aug 08, 2011 10:31 am
drill. mount mirror with nut bolt combo. after everything is tight and where you want it, tack weld the nuts to the inside of the door.
viewtopic.php?f=17&t=22188
PostPosted: Mon Aug 08, 2011 10:47 am
I figured that might be the path, but I don't see a way to get to the back side of the door panel. There is alot of other metal in the way.
PostPosted: Mon Aug 08, 2011 6:37 pm
How about Rivnuts or Nutserts? These are basically blind rivets but they are hollow and threaded.
PostPosted: Wed Aug 10, 2011 12:43 pm
those would work too.
PostPosted: Thu Oct 27, 2011 8:01 pm
:tu: Yes rivnuts or whatever they are named.Thats how I did mine.
similar to a rivet but with a threaded I.D..Just make sure they go in at the correct angle.Not straight on.
No need to access the inside of the door.
