It is currently Tue Jun 18, 2013 9:02 pm
 Post subject: Reseting springs lower/Compressing springs
PostPosted: Thu Jun 23, 2011 7:29 am
Does any one no of any cheap-ass way to heat up your springs and compress them , I dont want to chop them . I found one place but he wants $350 -way to much .
Has anyone seen this online on another forum or something i need some ideas that dont involve death .
1975 TX Gemini Sedan "Nana"
1977 TC Gemini Coupe G200z T
1984 TG Gemini Sedan G180z T
1989 JT150 Irsmcher -SOLD-
 Post subject: Re: Reseting springs lower/Compressing springs
PostPosted: Thu Jun 23, 2011 8:02 am
my old boss put my cougar on a lift, heated the springs with a torch and lowered it to the ground (still braced by the lift) to let the springs cool until he was happy with the way it sat.
that's about as specific info as i can give you. :oops:
'74 コロナマークⅡ
The 'Mistress' http://japanesenostalgiccar.com/forum/viewtopic.php?t=11540&postdays=0&postorder=asc&start=0
PostPosted: Thu Jun 23, 2011 8:12 am
:tu: very good , thank you .. more pls
PostPosted: Fri Jun 24, 2011 4:09 pm
please dont heat the coils with an oxy, it really messes with them and can cause spring failure fairly quick, I have seen a few cars damaged fairly badly from spring failure after this treatment. Heating the coils or cutting coils are illegal here in S.A.
I have used industrial springs here in Adelaide to compress coils before but they are a proper spring works, and do it properly. For the 350 you were quoted you should be able to get new coils for the beast, how low are you wanting to go? even check the gemini forums for second hand coils at the hieght you want.
PostPosted: Fri Jun 24, 2011 10:25 pm
ok thanks for your kind advice my freind . RB springs are hard to get s/hand and was hoping to save some money , i will have to go down this path after my other projects are finished
