It is currently Wed May 22, 2013 3:25 am
 Post subject: 81 Celica - 22R Motor - Will not stay running
PostPosted: Sat Apr 09, 2011 7:23 pm
Ok, so the weather finally nice and had time to look at the car.
Problem: car runs but will only run 6-10 mins tops then dies and will have to sit for a while before I start it again.
I checked: Fuel getting in carb ok, did not see any vacuum leaks or disconnected vacuum hoses.
I changed: Mechanical fuel pump, fuel filter, plug wires + ignition coil wire, new battery, cap, rotor, air filter too
I was asked on another forum if ignition coil overheating, did not notice to be too hot, but had a damp rag and put on top of coil when temp feels a little hot. Could it be the coil and igniter (ICM)?
If it's the coil, what's the best alternative to replace the coil and igniter. I checked the ICM and it's about $300 at rockauto.
I've seen an MSD 6A (6200) + Coil Blaster 2 on an 81 Celica. Will this setup work? How hard is it to re-wire for the MSD & Coil?
Anyone has the correct part numbers to buy for the setup.
Thanks in advance to everyone that comments
PostPosted: Sat Apr 09, 2011 8:44 pm
how's the weather in NJ (New Jersey?) now? you guys at in Spring? Only asking as the fuel may be vaporising.
Check the distributor as well. I had the exact same problem on a Ford Laser once (they were sold in the US as well, no idea under what name though). Turned out that a diode or something similar inside the distributor would get hot after a few minutes of running and kill the spark. Only worked it out as a auto electrician friend had the exact same problem on the same model car a week earlier!
PostPosted: Sun Apr 10, 2011 6:33 am
Yup, it's spring with about low 50's - 60's.
I got a suggestion of doing an OHM test on the pickup-coil in the distributor. But since the pickup coil and new coil is not that much may be wise to change it.
Thanks
PostPosted: Fri Apr 15, 2011 8:06 pm
It turned out to be a bad ignition coil. Runs like how it should now :)
