It is currently Wed May 22, 2013 4:31 pm
 Post subject: Wiring question for 1J swap.
PostPosted: Fri Apr 01, 2011 9:36 am
I've made the decision to swap in a 1j into the 'Mistress' for now, but i'd like to keep the factory gauge cluster if possible. If I can use the factory gauges, I plan to do the swap when I get back from my deployment, if not, i'll wait.
I know Oracles needed a gauge cluster out of a car that had a 2j already to go with his.
But, this guy did a 1j swap and was still able to use his factory cluster.
If anyone knows how I can accomplish this or get ahold of this guy to ask him, please let me know.
I've sent him a message on myspace, but he hasn't responded yet :cry:
to sum it up...
how can i accomplish-
74 Corona Mark II
1JZ-GTE engine/mission/harness
Factory gauge cluster
and any other wiring info that would help to make it all work. :tu:
'74 コロナマークⅡ
The 'Mistress' http://japanesenostalgiccar.com/forum/viewtopic.php?t=11540&postdays=0&postorder=asc&start=0
PostPosted: Fri Apr 01, 2011 3:52 pm
You can do the swap and keep the guage cluster but with newer guages.
check out speedhut.com
I am getting a set from them
PostPosted: Fri Apr 01, 2011 5:24 pm
I thought about that. If I don't use the factory cluster, I have a set in mind, but they won't go in until I redo the whole interior which is why i'm trying to use the factory one for now.
'74 コロナマークⅡ
PostPosted: Sat Apr 02, 2011 10:16 am
Use the factory cluster but just change the guages inside.
It will still look stock
PostPosted: Sat Apr 02, 2011 10:17 am
PostPosted: Sun Apr 03, 2011 8:01 pm
haha, yea, that slipped my mind for some reason. :oops: :tu:
'74 コロナマークⅡ
PostPosted: Fri Apr 08, 2011 10:19 am
That's Eddie M. (Old Series Garage) he's the one doing the swap in my 1980 Cressida (1JZGTE VVTi) and I too cannot use my stock gauges.
So Im going to use the cluster and get some aftermarket gauges to put in them, just like Oracles suggested :) :tu:
1980 Cressida MX32
Old Series Garage
