It is currently Thu Jan 29, 2015 1:36 pm
 Post subject: Carb cleaning/polishing? Has anyone done it?
PostPosted: Fri Feb 11, 2011 9:22 am
I am about to do a MILD rebuild on my weber DCOE for my Civic and in my searches and in my weber books there are all these shots of beautiful shiny webers. Now, mine isn't dirty, but it certainly isnt shiny. I have some basic tools, including a dremel.....has anyone here polished a carb? How did you go about it?
The air cleaner is polished as is the valve cover (but I took it somewhere to get it done)
Id like to make this look nice if possible...any tips would be great!
PostPosted: Sun Feb 13, 2011 9:16 am
I heavent seen any polished carbs, wouldnt waste time with that In my opinion(as the filter goes over it and its practically not seen).Ive seen some carbs that look pretty well painted.
PostPosted: Wed Feb 23, 2011 6:11 am
I think the way to do it is to have it bead blasted.
Cam mountain I feel different from the ordinary
AE86 Levin GT
KE15 Sprinter SL
TE27 Levin
PostPosted: Sat Feb 26, 2011 10:17 pm
certain parts may have been chromed or given a zinc coating.
mind you, I cleaned my wheel caps with some kitten number 2 and a dremel buffing pad. the number 2 has a cutting substance in it, cleaned them right up, then I polished them with a fresh buffing pad and some car polish.
before:
after:
PostPosted: Wed Mar 09, 2011 1:55 am
Soda blasting brings cast alloy up really well. Im currently doing a carby resto and im looking into an acid that is used to clean truck and boat alloy parts, its supposed to bring them up like new.
PostPosted: Wed Mar 09, 2011 2:10 am
Please do NOT polish the carbs from that point where the fuel is purified (so basically from the butterflys to the engine intake). You can smooth the walls, but not polish it as the air/fuel mixture would get back to fuel drops at the wall when they are polished.
Cheers,
Daniel
Current cars:
Daihatsu Hijet S85
Daihatsu Charade G11 + G102
Daihatsu Cuore/Mira L201 + L501 + L701
http://www.Hijet.de/
PostPosted: Wed Mar 09, 2011 2:22 am
^ what he said. I meant more on the outside. You want the inside to be roughly like a golf ball surface
(or shark skin).
