It is currently Tue May 21, 2013 3:08 am
 Post subject: MSD Ignition
PostPosted: Sat Nov 06, 2010 10:17 pm
is there any clear benefits from using it?
are they able to be used with carb cars?
PostPosted: Sun Nov 07, 2010 2:15 am
Sure can work with carbs: http://www.japanesenostalgiccar.com/for ... p?p=100788
PostPosted: Sun Nov 07, 2010 2:20 am
I dont really care for them personally. Go spend the money on some carbs or a cam instead.
31 3000gt vr4
88 starion x2, 83 starion
88 cordia turbo
86 mighty max 4x4
78 lancer
73 galant coupe
65 Debonair Deluxe
80's Hero
PostPosted: Sun Nov 14, 2010 12:29 am
But once you've already spent money on your cam and carbs.. an MSD is a nice toy too :D
I have a Digital 6 in my Lancer with all the goodies... high speed retard and launch control installed. :twisted:
www.1stgenlancer.co.nr
PostPosted: Sun Nov 14, 2010 3:58 pm
I use one just for the convenience, new technology, new wires. Gotta be better than 40 year old stuff
- Kurt
PostPosted: Wed Nov 17, 2010 3:11 am
I recently installed one into my cammed corolla, made a world of difference down low in the rpm range!
PostPosted: Sun Dec 12, 2010 6:18 am
slo-030 is right u do feel a diff down low and up high.. it also evens out your idle.. it will also allow u to open up your spark plug gap more. if u have carbs you will notice the diff as it will burn the fuel more and give u extra ponies and increase your mpg's ... i have msd 6a with ss coil and a gap of .50 on 77 810 datsun
PostPosted: Wed Jan 12, 2011 4:21 pm
Plus they are waaaaaay cheaper than a ignitor for a Toyota......
Plus u can go the cheap route and use a hei module
Rob Wala
85 Toyota Hilux
82 Toyota Corolla
78 Toyota Corona
71 Datsun 510
PostPosted: Tue Jan 18, 2011 5:53 pm
hey guys,
I have an MSD 6AL 2 with 2 step rev limit and launch control on my 2T-G with 45mm Webers. It has eliminated the miss at high revs with the standard toyota igniter and Bosch GT40 coil. I use it with a magnetic pick up from ra60/40 22r/20r motors. It hasn't missed a beat since.
I launch at 6500rpm and final rev limit to 8800rpm.
I recently also bought an MSD timing computer for a more linear timing advance.
The mechanical weights for timing advance was a pain driving the car on the street. I took them out and locked the distributor:
I also marked the crank pulley for reference on the amount of advance:
So far the car has been a lot smoother to drive and I am able to adjust the total advance with a timing retard option on the timing computer if the advance is too high.
MSD is a great product and I would recommend it to all, so simple to install and easy to use. You are able to retard the total timing by 4/3/2 or 1 degree if you like.
PostPosted: Tue Jan 18, 2011 7:41 pm
That timing computer is neat! I looked it up, and the pre-programmed advance curve should be pretty much perfect for any nostalgic
PostPosted: Tue Mar 29, 2011 10:58 am
I bought my MSD and Coil, but my mechanic said he doesnt want to install it yet because my car is smoky.....does this have anything to do with that?!!
PostPosted: Tue Mar 29, 2011 2:02 pm
It may or may not. I think your mechanic just wants to fix the smoking problem first. If you install the new parts, it may fix the problem or it may just mask the problem. Better to find the true cause of the problem first, fix it, and then install new parts.
