It is currently Wed May 22, 2013 8:49 am
 Post subject: source for strut info & dimensions?
PostPosted: Mon Jan 24, 2011 12:17 am
So I'm messing around trying to find the shortest possible strut insert for my mx73. But, I'm having trouble finding a good source of dimensional information. So far, I have found a few possible swaps (ae92 and mk1 golf), both of which I have been told are quite a bit shorter than mx73 strut inserts (by about 2"). Mostly, I'm trying to find out what is going to match up closely in diameter with my mx73 strut tubes, and still be shorter by at least 1".
If anybody knows of a source or website where I can access cross information it would definitely help me out!!
PostPosted: Thu Jan 27, 2011 4:14 pm
Would also like to know this too.
- Travis
Yes I CURRENTLY own all of these.
AE86
AE100
JZX32
MX63
JZX73
MX83
JZZ30
RN65
VZN130
VZN185
PostPosted: Thu Feb 03, 2011 6:52 pm
koni has all their dimensions for their struts. you might have to try a bunch of different cars struts cross reference to the koni site, then look at the specs.
86 starion. 71 510
PostPosted: Fri Feb 04, 2011 4:23 am
Toyota Camry SV10 got shorter strut insert..
PostPosted: Sun Feb 06, 2011 10:53 pm
Well if they are 43.5mm OD inserts, there is a lot of info on insert dimensions on the various AE86 forums. For example, I have just put SW20 MR2 AGX inserts in my AE86 struts.
PostPosted: Fri Mar 04, 2011 8:28 pm
is it possible to use the MX83 hub on the MX73 strut?
PostPosted: Fri Mar 04, 2011 8:51 pm
http://gabriel.com/documents/Gabriel_Ca ... _12_11.pdf pages 273-291 has a complete breakdown of extended length, collapsed length, stroke and end types
Information = POWER
PostPosted: Sat Mar 05, 2011 6:09 pm
^ thank you! Very much appreciated!
