It is currently Sat May 18, 2013 4:53 am
 Post subject: Fender mirror installation help...
PostPosted: Thu Jan 20, 2011 5:26 pm
I just received a set of mirrors for the fenders of my car and am not too sure of how to mount them. It looks to have a guide screw, but the thing that throws me off is this set has the spring that comes down off the base and the base is a silver/metal rectangular piece that, I assume all goes on the inside of the fender.
Could someone please help me out with some sort of step-by-step with install?
Thank you in advance!
PostPosted: Thu Jan 20, 2011 6:30 pm
Yes, all that goes inside the fender. Take it all off, drill the mounting holes through the fender, snake that long stud through, then reassemble it all inside the fender. That silver metal plate rides up against the bottom of the fender (on the inside).
The spring is there so that if someone walks by and accidentally bumps the mirror they won't break it off. :wink:
PostPosted: Thu Jan 20, 2011 6:42 pm
Also, if there's a plastic/rubber "gasket" at the base of the mirror itself, obviously that goes between the mirror and the fender, not underneath. :tu:
PostPosted: Thu Jan 20, 2011 9:53 pm
I guess it'd be easier to do with the fender off, yes?
PostPosted: Fri Jan 21, 2011 4:15 am
Maybe, depending on car, how tight is the room under the fender.
I've never had to remove a fender to install one, yet.
http://olskoolparts.blogspot.com/
PostPosted: Fri Jan 21, 2011 7:37 pm
Easier, yes. But when you add up the hassle of removing the fender plus the mirror install, compared to just the hassle of the mirror install with the fenders on...
I usually keep them on. 8)
PostPosted: Fri Jan 21, 2011 7:39 pm
And if these are going on the Civic, what are you going to do with the Napolean/Phantom mirrors you're taking off? 8)
PostPosted: Sat Jan 22, 2011 7:21 am
^^^ I'm sure I'll get rid of them, sir....
The only problem I encounter with leaving the fenders on is the wheel well gets in the way of moving about. I'll check out in a few, though.
PostPosted: Sat Jan 22, 2011 12:06 pm
take off your wheel first..
if you decide to take off the fender, keep in mind you measure were to drill the holes with the fenders still on the car.
Japanseklassiekers!
1970 C30 Laurel
1972 240Z
1973 610 Wagon
1977 260Z
1995 Micra
1999 200SX
PostPosted: Sat Jan 22, 2011 7:42 pm
This is exactly what I did. This enabled me to NOT have to remove the fender after all.
 Post subject: Re: Fender mirror installation help...
PostPosted: Sat Nov 17, 2012 9:49 am
hi all JNC members, HTH
first thing is, make 2 holes on the fender
(if original fender did not have the holes)
1st hole for the spring
2nd hole for the guide screw
feel free to log on to:-
http://www.olskool.my/forum
https://www.facebook.com/groups/olskool.org/
PostPosted: Sat Nov 17, 2012 9:53 am
next step, put the base plate mount on the fender
remember those zinc plate put beneath the fender
PostPosted: Sat Nov 17, 2012 9:54 am
finally insert those mirrors :mrgreen:
