It is currently Thu May 23, 2013 8:08 pm
 Post subject: headlight condensation
PostPosted: Tue Oct 19, 2010 5:51 pm
hi everyone, i just recently picked up a first gen crx and it has water condensation inside one of the headlights. does anyone have any tips for getting the water out? i do believe the headlights are glass if that makes a difference
PostPosted: Tue Oct 19, 2010 6:03 pm
The condensation is usually because of a "leak" in the light. Only real options are to disassemble and reseal (tricky job), or buy new ones. :cry:
Unless of course the leak is something obvious, like a crack in the housing?
PostPosted: Tue Oct 19, 2010 6:05 pm
Just to clarify, your headlights look like this, right?
NOT like this:
PostPosted: Wed Oct 20, 2010 4:27 am
time to get some EDM black housing lights... like this:
check www.redpepperracing.com for some or some stock ones too.
PostPosted: Wed Oct 20, 2010 5:31 pm
theres no obvious crack or anything that i can find, i cant see the first image that u posted datsunfreak but i can see the second pic and those are not what my headlights look like. id rather try to fix them then buy a new set. so what exactly would it take to fix them, just disassemble the headlights and use like an epoxy or something to seal them back together? thanks for the reply's guys!
PostPosted: Wed Oct 20, 2010 6:11 pm
Exactly. And if they have vent tubes, make sure they aren't clogged up. :tu:
PostPosted: Thu Oct 21, 2010 4:16 am
yeah, check the vents first. those should be clear. if they aren't that could very well be the fog issue.
PostPosted: Thu Oct 21, 2010 6:28 pm
hmmm never heard of vent tubes lol, im guessing they are on the back of the headlight near the headlight bulb?
PostPosted: Thu Oct 21, 2010 6:31 pm
Yeah, little rubber elbow, usually just above the bulb socket. :tu:
