It is currently Tue May 21, 2013 9:21 pm
 Post subject: I've got a wheel question i'm hoping to get some help on...
PostPosted: Fri Oct 26, 2012 2:25 am
Hello fellow jnc lovers... I am wondering if anyone knows -if anybody has -or even knows if it would even work -putting wheels on a 5-lug 1991 camry/crown -like these mitsubishi starion wheels... would they fit???
if correct -they do share the 5x4.5 bolt pattern -yes? -yet i am wondering about the offset -and i do know they are intended for rwd -and a 1991 cam/crown is frd -and camber -stress all that -yet am just curios -if anybody has seen these on a 91 -and if not -likes doing some math and is a wiz etc. -and likes to share :) and would beable to tell me if they'd fit...
i'd also like to know ov all manufacture [yet stock] [even steel] that have that pattern which i could use -or are known to work???
i would be extremely grateful for any leads in this... always want to up my wheel tire combo -with junkyard finds...
sometimes i think about just getting some adapters and going crazy -picking some crazy combo...
yet i am sure a set would still be more than a set ov wheels that would work... -i really onlt want to go to 15 -might consider 16's -i do want to do a tire stretch -and keep the tread to a minimum -not looking for handling gains -solely for driving like grandma -around town :D
if someones knows ov a chart -where someone has taken the time to write down all car makes and the models etc. whom share the same bolt pattern -or at least just put the order ov the desciption in bolt pattern order -that'd be like WOW :shock: - and i'd want to know where to find such a thing...
thanx all - cheers
 Post subject: Re: I've got a wheel question i'm hoping to get some help on
PostPosted: Fri Oct 26, 2012 4:57 pm
Try looking at later model (1990+) RWD cars. For some reason manufacturers started putting FWD spec wheels on their RWD cars. For example, my IS300 has 17 X 7 50mm offset wheels even though it is RWD. Fouth Gen Supras were in the same general range.
PostPosted: Fri Oct 26, 2012 8:49 pm
I know that the 16x8 are -10 and will not fit on a 91 cressida... tried it myself. I doubt that they will fit a 91 camry/crown. Better off looking at fwd offset as the above said. Heck, even the MX73 cressida had a +20 offset. My starion wheels are being saved for the celica... just haven't decided if it will be the 76 or the 85.
1985 MX72 soon to be...
1991 MX83 soon to be 7MGTE
PostPosted: Fri Oct 26, 2012 10:09 pm
I like the starion swap. If painted right it looks like the stock celica gts or supra rims but 5 spoke.
PostPosted: Sat Oct 27, 2012 9:21 am
thanx all... and yeah -the way they look like five spoke versions is why they interest me so much -for this application... -i figured later model five lug rwd celica and supra wheels would fit -and have taken them into consideration for sure... there just not as cool as early model wheels -and i want to go with old school -making my 91 look even older than it is :D
i am thinking about just doing steelies like Image
and painting the rims -as i have already done on my 14" stocks -yet going bigger etc. and stretch the tires...
or trying something like http://raleigh.ebayclassifieds.com/m/ViewLargeImage?adid=13424732
and getting some moon hub covers -and rim rings maybe?
i've often though ov getting adapters as i stated earlier -yet don't even know how much i'd be looking at to get something custom -as i don't think there is anything made for the ap. i'm thinking about... like to aircooled vw wheels -which would be taller -and thinner than mine -and now a days -or if ever -are larger wheels so thin... i like getting better gas milage -and less drag... though i am unsure they'd even be up to the weight -haven't done the math on that... XP
have also tooled with the idea ov going smaller too -to something classic as Image
with adapters ov course... could be fun -less gas milage -yet for around town not much... and a bit quicker off the line :D
or adaptor on the old celica supra wheels -hmmmmm????
also really like these Image
and would need adaptors -sooo idk -guess it's just really a matter ov money
most likely will go with the cheapest thing i can find second hand -that'll work...
thanx again
PostPosted: Fri Nov 02, 2012 6:03 pm
Moved to proper forum.
