It is currently Sat May 25, 2013 7:56 pm
 Post subject: 1984 Gemini Sedan .. Street/Strip/Track/Show Beast .
PostPosted: Thu Jun 02, 2011 11:45 am
Hi My next project i want to share is for my 1984 Holden TG Gemini Sedan.. Although built by Holden its all still an Isuzu to me..
This car was purchased in May 09 for $2500 in great condition with no rust or dings and a good factory interior with a Tacho dash.. It came with a fresh 2L EFI motor so all the hard work had been done.. :D
Specs when First Purchased :
G200Z 2.0L SOHC (Balanced and rebuilt)
G161Z 1.6L Head
Rodeo EFI
Lumpy Cam
Extractors
2.5" Mandrel welded exhaust
Delco ECU
Rebuilt 5 Speed
New Aircon
Lovells Springs
Monroe shocks
Piazza front brakes
At this early stage i fitted :
Clear indicators with LEDS
14" Rims
Isuzu Grill Badge
Custom plates
SAAS Race bucket
Jap Steering wheel
New Gear Boot
Custom Shiftknob
Early model window winders
Hard plastic Jap door handles
Chrome Rocker Cover
Chrome Oil cap
SLX/ ZZ/Z Tacho Dash , standard tape deck , Billet ebay shift knob
Came with the clean SLX Interior , I added the early model winders and hard plastic jap door handles
G200Z 2.0L SOHC with Rodeo EFI fitted
A month or so after i bought it i made up a cold air feed and hit the drags.
Takeoffs were pretty slow without LSD or a welded locker diff .
Best 60 Foot Time: 2.209
Best E/T:16.124 TrapSpeed:80.41kph
Horsepower: Approx 100hp
And then about August '09 i was coming home from work and driving directly into the dusk sun , i was blinded badly and this happened .
So then i sourced a good bonnet,LH guard,Radiator support and some headlights and a grille. Dropped it at a friends panel shop ..
These are the shots from the shop in September 09
Radiator support replaced
Battery plate removed
Then on December 23rd 2009 i got it back from the shop painted in the factory metallic color and i put it back together.
Parts fitted at this stage :
NOS Hard plastic bumpers
More Clear indicators
Repro Taillights
NOS Holden badge
Repro Sandpiper/GTS mirrors
15 x 7 O.Z. Racing rims
215/50 Dunlop Formula R Tires
Then i got my simmons i bought of Kev reconditioned
Best money i ever spent :D
Simmons 15 x 7
Running Firestone 195/55/15 tires
Modifications & Parts fitted in this stage:
Odyssey Dry Cell Battery Mounted in boot
Whiteline 18mm Rear swaybar
Whiteline 24mm Adjustable Front Swaybar
Nolothane Oncar adjustable Panhard rod
SuperPro Suspension and steering Bush kit
Pedders sports short shocks Front and Rear
Kings Springs SuperLow Front Springs
Slotted front ball joints
Pinion angle washers
H/D Torque Tube
H/D Torque Tube Rubber
VK LSD Diff Center
Chrome Diff Cover
Alloy Radiator
14" Thermo Fan
Thermo fan controller
New air con Condensor
10" thermo
CDT Front spoiler
ZZ/Z F/Glass Mudflaps
LED Taillights
Haltech E6X Fully Programmable ECU
Quad coils and M+W Ignitor
F/Glass Kickpanels
Custom Rocker Nuts
Painted valve cover and heater cover
Next i fitted a Small Odyssey battery to the Boot ..with a nice metal plate ,some sweet Brackets and a battery support.. Solid as
Then i Fitted Front and Rear Whiteline Swaybars before my first Superkhana Image
.. Rear is a non adjustable 18mm type that is a Straight swap in the same position as standard
.. Front is Adjustable 24mm type ..
..I needed a smaller Oil filter , big one cleared but id be removing part of the swaybar for oil changes .. So went down From The 56 to the 79 i think..
Also got an Entire Superpro bush kitted out thru the whole car
Some Pedders short Sports shocks and some slotted ball joints for increased Camber.
Bought and fit a Heavy duty Torque tube rubber and got my Torque tube sleeve to stop it bending , and fit some thinner spacers under the Tube mount to improve my pinion angle since my car was much lower.
I also fitted a Nolathane adjustable panhard rod and a VK LSD diff center which later diedImage
Got a chinese ebay Alloy radiator and a new aircon condensor and got it all Gassed up..
its Cold
Then it was my CDT front spoiler that was fitted up ..
Looks ok .. Takes a bit to get used to .
Not long after that i went to the drags on a Wednesday night.. 16.054 was the Best i could get .. LSD hooked up tight all night , with no sighn's of the failure to come in a few months time... Some vids
http://www.youtube.com/user/GEMWRC#p/u/0/m0hx4URqC-M
http://www.youtube.com/user/GEMWRC#p/u/1/FLcWTSOvf9M
Smokes up good with the New tyres Pumped up and Dropping it in 2nd
Then i entered my first Superkhana. And yes i was much faster than the Datsun 1600Image Vids:
http://www.youtube.com/watch?v=E1jFn7W1JUY
More Dragracing Next : http://www.youtube.com/user/GEMWRC#p/u/0/OBvMvDSvVkE
http://www.youtube.com/user/GEMWRC#p/u/0/ggcq5IspBJo
Swapped out my rear globes for some LED types
Then i Fit some Kings Superlow front springs with one coil axed off Image
After that i put on my ZZ/Z Mudflaps
And my Haltech E6X
With Quad coils and M+W Ignitor
Got my Dash repaired
And test fitted my Factory dash undertray.
Tried out my F/glass Kick panels
Then i had another SuperKhana
After the SuperKhana my diff was very noisy to the point were it locked up on the street. Leaving me hereImage
The pin slipped out and it was Game over
Put a standard Diff back in and finally fit my Valve cover , with Custom nuts and my heater cover
1975 TX Gemini Sedan "Nana"
1977 TC Gemini Coupe G200z T
1984 TG Gemini Sedan G180z T
1989 JT150 Irsmcher -SOLD-
 Post subject: Re: 1984 Gemini Track / street / strip/ show Beast
PostPosted: Wed Jun 08, 2011 11:50 am
Whats a build thread without photo updates... Boring !! .... Image
Next installment
Around September 2010 i bought my Coupe and this came of the road again for more work.
The next modification was the fitment of a Custom remote shifter mechanism ... As you can see the standard gemini gearstick comes out of the tunnel on a large angle quite a way forward compared to most cars
This adaptor bolts to the quadrant box moving the shifter down the tunnel to a more freindly position ,whilst also shortening the distance between shifts ..
Only install pic i took with half the bracket installed
Here it is all fitted up with .. The Gemini Automatic Transmission Center console fits perfectly. Image
Next i fitted my Base model TE / japspec Grille and Round headlight Combo, still dont know if i like it , so i have kept my other set of headlights and grille.. I also have a a ZZ/Z and a ZZ/R front spoiler to test fit.
I had some Custom white faced gauge backgrounds made up , i had these installed by an Instrument shop in balcatta as i heard many stories of them being ruined and uncalibrated when the needles were removed at home. They also scraped the white paint off my needles so they were clear and then painted them in a special orange paint .
Before
After ..
Big problem with my design .The black letters and incrememnts do not let the light thru . I had them remade with outlined numbers/increments to hopefully fix the problem. (yet to fit) Image
Basically from here is the start of my Turbo Conversion .. Originally i had a Ballbearing '01 WRX Turbo adapted to a Piazza Cast Turbo manifold i was going to use , but them i bought Petes Coupe and decided to Buy a larger Turbo for the sedan and aimed for at least 200hp at the wheels WITHOUT forged pistons or rods . At this stage my engine was only 40,000ks old and collected some parts.
Garret GT2871 rated@440hp and GemRacing exhaust manifold
GemRacing Stainless Steel Dump pipe
Also got 2 pairs of braided brake hoses for both cars Piazza Front brakes.
My spare room . 440cc injectors , Custom Plenum , New Diesel Gem Radiator , billet camshaft , 20mm adjustable rear swaybar
Got my race seats re-upholstered
Test fitting intercooler . 530x230x69 It Fits !!
It took a lot of playing to get the right combo of fan sizes and order to be able to fit this with air conditioning. It was never going to fit with my aluminum radiator , so this was sold and i had a larger gemini diesel radiator reconditioned and bought some thinnner thermo fans. Image
Started on the motor , My 2L motor has a 1.6L cylinder head fitted for higher compression , I wanted to swap this for a 2L head to keep the comp a tad lower
Removed the head at home then took my car to Dads work and pulled the motor to fit a Sump with an Turbo oil return
Happily we discovered the motor had been balanced in the previous rebuild.
I also fit a Double row timing chain and sprocket kit
After some grinding and filing work i got my Plenum fitted to my lower Rodeo Runners . These were then powder coated by Dads mate as a favour.
I needed to buy some bolts as the studs fouled under the plenum , also painted my VL throttle body .. About now i realized i had forgot to get a accelerator cable bracket welded onto my plenum Image
Around this time Feb 2011 , i killed my Coupes motor , and this project got put to the side for a little while , Bad news is next update may be a while away but it is going be Killer
 Post subject: Re: 1984 Gemini Sedan .. Street/Strip/Track/Show Beast .
PostPosted: Wed Jun 08, 2011 12:34 pm
top work there :tu:
PostPosted: Wed Jun 08, 2011 7:19 pm
LOVE the round headlight conversion! :tu: :mrgreen:
Never seen this style grill before.
PostPosted: Wed Jun 08, 2011 10:36 pm
Thanks guys . this grille is only fitted to the very basic poverty pack TE Geminis in Australia , Quite hard to find nowadays as they were the ugly duckling back then and break around the lights very easily ..It was a lot more common on the jap gems.
PostPosted: Thu Jun 09, 2011 9:33 am
The front spoiler & mudflaps look killer, I love it!
