It is currently Sat May 18, 2013 3:15 am
 Post subject: lowered 87 pickup stolen in downtown seattle
PostPosted: Sun Dec 16, 2012 2:07 pm
call police if seen
 Post subject: Re: lowered 87 pickup stolen in downtown seattle
PostPosted: Mon Dec 17, 2012 12:28 pm
Lame!
I'll keep my eyes open for ya.
'76 LUV
'92 GTI 16v
PostPosted: Mon Dec 17, 2012 9:55 pm
thank you
note: had to break the links to make the forum happy, more pics and info in my build thread, link at bottom.
img]http://i81.photobucket.com/albums/j204/CB_shonuff/87%202wd/IMG_1329.jpg[/img]
here is a parts/unique piece list of stuff to watch for
17x8 97ish mustang cobra wheels 245/45/17, 2 of them have marks under the center cap on one lug hole from me removing a wheel lock i lost the key to, the other 2 have camber wear on the inside of the tire
similar "buckle" dents and rolled flat and tugged on both fenders
djm 2in spindles, broken off steering stop in drivers side, no wheel stop on pass (passenger caliper is painted red)
bed has a hole on front passenger side for no reason
img]http://i81.photobucket.com/albums/j204/CB_shonuff/87%202wd/IMG_1361.jpg[/img]
another dent in the rear pass corner, and a big cartoon racing sheep sticker, "I'm dragging my member" lic plate frame
img]http://i81.photobucket.com/albums/j204/CB_shonuff/87%202wd/IMG_1386.jpg[/img]
blue cloth 60/40 bench seat, tear on drivers side bottom with a white towel stuffed in it
custom made stock throttle linkage spacer
img]http://i81.photobucket.com/albums/j204/CB_shonuff/87%202wd/IMG_1437.jpg[/img]
offenhauser dual plane 22r intake with 2in weber 32/36 adapter/riser. bolts are stripped and stacked with washers on the thermostat and the carb/riser holes have been stripped and used oversized non standard toyota bolts
as it was in the truck
img]http://i81.photobucket.com/albums/j204/CB_shonuff/87%202wd/IMG_1463.jpg[/img]
img]http://i81.photobucket.com/albums/j204/CB_shonuff/87%202wd/IMG_1432.jpg[/img]
most carb bolts were tapped out to a 9/16th bolt to mount the spacer, forget the pitch
painted grey w/ black spots 4in steel drop blocks
home made front passenger body mount ( whole core support replace from FD corner to the pass fire wall and is gloss black)
flow master muffler welded to a stock 22r manifold w/hanger (muffler has "melted strap stain"...long story)
fairly new gabriel hi-jacker air shocks
img]http://i81.photobucket.com/albums/j204/CB_shonuff/87%202wd/IMG_1360.jpg[/img]
hood has half ass body work and is painted mostly semi gloss black with a big ol primer spot
red top optima with a plastic sticker pouch with the receipt in it on the motor side
here is a link to my build thread for more pics, thank you very much for looking
http://blacksheepauto.com/forum2/index.php?topic=284.0
PostPosted: Tue Dec 18, 2012 6:03 pm
My guess is that it was stolen for the wheels or motor and then abandoned. Has happened to me before.
Kane
PostPosted: Tue Dec 18, 2012 8:10 pm
Ya, this isn't my first time. Actually think they came back to steal my wheeler again, but the mini was in the way
PostPosted: Fri Feb 01, 2013 12:16 pm
RECOVERED!!!
Missing the batt, stereo and rear shocks with only minor repairs needed.
Stoked :D
PostPosted: Fri Feb 01, 2013 3:27 pm
Nice!!! Glad you got it back with minimal loss.
