It is currently Sun May 19, 2013 4:40 pm
Post a new topicPost a reply Page 3 of 3   [ 43 posts ]
Go to page Previous  1, 2, 3
Would you like to see a JNC / Grand JDM Dictionary?
Yes 92%  92%  [ 22 ]
No 8%  8%  [ 2 ]
Maybe 0%  0%  [ 0 ]
Total votes : 24
PostPosted: Mon Jun 02, 2008 7:32 pm
Interesting!
In Aus the two major sellers of utes - Ford (Falcon) and GM Holden (Commodore) now have the rear bed split from the cab. But they are still both essentially car based. But the "split" only happened in the last five years or so. BTW A ute with a tray-back in Oz is generally called a "Tonner" as they were traditionally rated for a one ton payload. Example:
An F250 would still be called a ute down here anyway.
Brett Nicholson
Melbourne, Victoria, Australia
75 Corona RT112 JDM Coupe 18RG
85 MR2 AW11 USDM 4AGE
74 Volkswagen Superbeetle 1303L
71 Mini Moke
65 Mini Traveller
09 Nissan Pathfinder
 Post subject: English (American English) to Japanese Car Phrase Dictionary
PostPosted: Mon Jun 02, 2008 8:46 pm
OK, this is a transcription of a two page English to Romanji “dictionary” from Tuner Performance Reports, apparently written by Phi Phung and Naoto Negishi. They did not use dashes for long sounds in their translation. A double letter, a dash, and an “o” followed by a “u” are are three ways to get long vowel sounds, but each are typed differently… I don’t know what dialect or regional accent that Phung and Negishi learned, mine is apparently Nagoya/Fukuoka, which probably influences my corrections. My corrections are in parenthesis.
Parts – Patsu (pa-tsu)(also buhin)
Main bearing - oya metaru
Rod bearing – ko metaru
Fuel pump – nenryo pompu (this may actually be “ponpu”)
Oil – oiru
Exhaust manifold – eki mani
Header – tako ashi
Intake manifold – in mani
Air filter – ea kuri
Turbo – tabin (also ta-bo)
Hose clamp – hosu bando
Catalytic converter – shoku bai
Driveshaft – pera sha
Axles – dora sha
Shocks – dampaa (may be danpa)
Springs – bane
Tuning – Settingu
RPM – kaitensu
Ignition – tenka
Fuel – nenryo
Oil pressure – yu a tsu
A/F – kuunenpi
Cam timing – baru tai
Water temp – suion
EGT – haikion
Oil temp – yuon
Fuel pressure regulator – nen atsu regureta
Crank angle sensor – kuranku kaku sensaa (sensa-)
Stand alone computer – furu kon
Piggyback computer – sabu kon
Valve adjustment – tapetto chou sei
Broken – kowarete masu
Crack – hibi
There is a crack – koko ni hibi ga arimasu
Hot – atsui
Cold – samui
Burning – moetemasu
Tight – kitsui desu
Oil leak – oiru more
Coolant leak – mizu more (mizu should be for drinking water, may not be accurate for coolant)
Metal/wire – Metaru
Weld – yousetsu
MIG weld – han jidou yousetsu
Welding rod – you bou
Stainless steel – suten
Steel - tetsu
Pipe – paipu
Flange – furanji
Solder – handa zuke
Soldering iron – handa gote
Screw – neji
Thread – neji yama
Anti seize – surredo kon paundo
Tools – Kougo
Combo wrench – supana
Pliers – penchi
Dikes – niipa
Hammer – tonkachi
File – yasuri
Screw driver – doraiba
Phillips screw driver – purasu doraiba
Rag – uessu
Dyno – shashi dai
Feeler gauge – shikki nesu geiji
White – shiro (These are adjectives, usually followed by the letter “i” unless used as modifying adjectives)(shiroi)
Black – kuro (kuroi)
Red – aka (akai)
Blue – ao (aoi)
Yellow – kiro (kiiroi)
Orange – orenji iro
Grey – hai iro
Purple – murasaki
Black with white stripes – kuro ni shiro sen
Phrases (poorly conjugated)
Push here - koko wo osu
Pull here – koko wo hiku
Let it go – hanasu
How much torque? – toruku wa ikutsuka desu ka (toruku ha ikutsuka desu ka)
Doesn’t match – awa naii desu (chigai ga arimasu)
Something is wrong – nani ka okashii desu
Something is broken – nani ka kowaretemasu
Bigger – motto ookii no
Smaller – motto chisai no
I’m finished - owarimashita
Is there anything else? – hoka ni nani ka ariamsu ka
Turn on – tuskeru (tuskete kudasai)
Turn off – kesu (keshite kudasai)
Open – akeru (akete kudasai)
Close – shimeru (shimete kudasai)
Up – ue
Down – shita
Up lift – ageru
Down lift – sageru
Hold it at 2000 RPM – ni sen kai ten de osaette
I got burned – yakedo shimashita
I cut myself – kitte shimaimashita
$#!#%!#$# (universal curse word) – kuso
Peace out – pisu auto
I really like “Racing Words” by Debora Corsini, but it covers seven languages, is 747 pages, and all of the Japanese is in Kanji, Hirigana, and Katakana. I work much better in Romangi (English letter spelling of Japanese pronunciation). I will not be transcribing that book any time soon.
PostPosted: Tue Jun 03, 2008 1:37 am
RT112 wrote:
Interesting!
Brett, better also add the term "Tilly" here too. The 11 utes in my collection have all had that nickname from the original owners!
Users browsing this forum: billy goat and 3 guests
