It is currently Sat May 25, 2013 12:22 am
 Post subject: Carb trouble
PostPosted: Wed Jul 06, 2011 7:23 pm
I figured this is a general carb question that any other car brand can have so im gonna post it in general discussion.
I rebuilt this pile of shit a while back and it ran pretty decent. Its gotten nothing but worse since, b/c now it will not even idle and cuts off if youre not on the throttle somewhat. It smells and acts flooded while running but seems like its not getting fuel when I try to crank it. The mixture seemed fine just a few weeks earlier and I have not changed it. The only way it cranks now is if I spray some starting fluid in it. If you have ANY idea or theory as to what it could be, then respond with whatever is on your mind. Thanks
P.S.
Its an 8rc on a 70 corona mkII and everything on the ignition is in good working order if that helps.
-'70 corona MKII wagon
-'80 rx7 racecar
^Heres my build thread^
Packergreg wrote:
Hezath wrote:
Wagons pull the bitches
 Post subject: Re: Carb trouble
PostPosted: Fri Jul 08, 2011 7:22 pm
What sort of carb is it?
Will
'87 BMW M3
