Results 1 to 2 of 2
Thread: 4ac with k50 trans?
    Jul 2010
    Puyallup, WA
    4ac with k50 trans?
    So I have a 77 corolla ke30 with a blown engine, I recently came across a 4ac for dirt cheap and I was wondering is there is any way to easily bolt the 4ac to my stock k50 tranny.
    Any info on putting a 4ac into amy ke30 would be awesome!
    Aug 2012
    Montreal, Canada
    Re: 4ac with k50 trans?
    The only way to do this would be to find a K50 from a AE85 that was only available in japan... the K tranny doesn't have a removable bellhousing and K engine bolt pattern is different from A engine.
    On a good side, a T50 tranny from a TE2x, TE3x TE5x, etc will accept your stock driveshaft, same output spline count, same dia and same tranny length... and it will bolt behind a 4A bellhousing with minor modification (but you need a 4A-C manual bellhousing to pull that one off...
    Or you could get a whole 4A with it's T50 tranny but you'd have to cut the transtunnel a little to accomodate the shifter that sits a couple of inch backwards and you'd have to swap the driveshaft yoke for an AE86 22 spline yoke... but overall length is the same.
    Hope that helps you.
  1. 5-Speed Trans behind a 2M
    By mjacobs11 in forum Toyota Garage
    Last Post: 08-12-2015, 12:32 PM
  2. WTB manual trans T50
    By 83crown in forum Toyota Swap Meet
    Last Post: 03-28-2015, 08:24 PM
  3. FS: 510 SR/KA trans crossmember
    By lowlifestyle in forum Datsun/Nissan Swap Meet
    Last Post: 07-24-2013, 12:07 AM
  4. WTB: W40 or W50 Trans
    By vegascorona in forum Toyota Swap Meet
    Last Post: 10-29-2012, 06:12 AM
  5. 18rc and w40 trans
    By daruma in forum Toyota Swap Meet
    Last Post: 01-28-2012, 06:09 AM
