Results 1 to 9 of 9
Thread: Anyone how a good "how to" remove clear coat off SSR's?
    Mar 2011
    Redlands
    66
    I went toget my wheels polished and they said that there is a clear coat on it and they couldent polish till it was removed. So what do you guys use?
    5,527
    Re: Anyone how a good "how to" remove clear coat off SSR's?
    Short of soft media blasting, paint stripper would work best. :tu:
    I've used this "aircraft stripper" before with good results, and no damage to the base aluminum. It's made for airplanes so it's safe for aluminum.
    Mar 2011
    Redlands
    66
    well i tried that stuff and it didnt even do a single thin. i let it sit for 30 minutes and nothing. i was told that some SSr's come with a clear anodized finish? have you guys heard of that?
    Sep 2009
    Los Angeles
    161
    I believe most clear coats on JNC wheels are anodize. I've heard Easy-Off oven cleaner works on it but it is nasty stuff and you need to be careful it doesn't damage the aluminum...
    Jan 2012
    Qld
    94
    i have used Mr muscle oven cleaning, worked well i think. this is a combo with paint stripper and prepsol. i did polish the rim so it wont look shiny like that normally.
    Mar 2011
    Redlands
    66
    So on those mk111 did you use the oven cleaner or that combo? How much of each did you use?
    Jan 2012
    Qld
    94
    nice thick layer and put them in the shad for 30min then hosed off
    Sep 2009
    Los Angeles
    161
    Quote Originally Posted by rkkopra73
    Oven cleaner works great on anodized aluminum. It does etch the aluminum though, so a polish will be necessary afterwards to make them pretty again. It will also damage any other surface it comes in contact with (including your squishy little eyes and lungs) so be sure you are in a clear area free of wind (travels like a sonofabitch). Wear long sleeves and pants, and for the love of all things holy some safety glasses!
    Robin
    Don't forget the thick, kitchen grade, rubber gloves!
    Feb 2010
    Geelong, Australia
    85
    you can rub the clearcoat off with thinners or acetone, and a whole lot of elbow grease.
    spray-on paint stripper works best from what i've found (the stuff in the rattlecan) and a warm and humid environment will make it most effective.
    try putting cling-wrap on the bit you're stripping to seal it, it'll make the process faster and more effective.
  1. 15" BBS RA Wheels, Very good, w/ Centercaps & Tires
    By greggearhead in forum Wheels Swap Meet
    Last Post: 01-09-2013, 03:24 PM
  2. Wanted Cannon Manifold 828 "S" type for Datsun "L20B" Motor
    By Danny in forum Datsun/Nissan Swap Meet
    Last Post: 02-23-2012, 11:13 PM
  3. j-line mesh wheels new 17"x10" and 17"x8" 0 offset on both
    By datzilla in forum Wheels Swap Meet
    Last Post: 01-06-2012, 11:19 PM
  4. SUBARU DL 1400 "LEONE" & "GSR" - IND
    By pomphy in forum Subaru Garage
    Last Post: 07-18-2010, 11:59 PM
  5. forget "Zombieland" or "Jennifer's Body"
    By baron von chickenpants in forum Off-Topic
    Last Post: 10-13-2009, 07:12 AM
